TractorLinks.com
Tractor Talk Discussion Forum
Re: Getting a Farmall A to fire
dr sportser
04-01-2013 14:35:11
You can't make statements like you believe you have no power. Get a test light or meter and start testing stuff. It sounds to me like you need a mechanical friend to come over and you just buy the beer.If you have postitve ground you may have hooked up the coil in reverse. That is the only thing you changed since it was running so check your coil connections. Coil connection reverse for pos vs neg ground systems. Check that if coil is correect jump past switch and test coil lead. If no spark go to inside distributor and clean contacts using clean bus card and lacquer thinner. Don't leave small bits of paper in points.
