TractorLinks.com
Tractor Talk Discussion Forum
Re: Getting a Farmall A to fire
rpbat
03-31-2013 18:19:37
The tractor was originally had a 6 volt system, my grandpa had the tractor converted to a 12 volt system many years ago. That was probably 30 or 40 years ago. Everything on the tractor was working when it was parked but it sat for almost 10 years.
dr sportster
03-31-2013 18:30:03
 Re: Getting a Farmall A to fire in reply to rpbat, 03-31-2013 18:19:37
If everything worked before and you did not just rewire this clean the points and it should fire right up. Sorry I can't be of more help but ---bedtime. Did you at least change the spark plugs or pull them and look at them. I never heard of a coil going bad in storage.What happened when you pulled the wire as in John T's instructions ? Did you get spark then? Got point gap ? Mouse chewed anything?
rpbat
03-31-2013 18:41:10
 Re: Getting a Farmall A to fire in reply to dr sportster, 03-31-2013 18:30:03
Well I have a brand new coil but it will not fire, what triggers the coil to send electricity to the distributor?
dr sportster
03-31-2013 18:52:40
 Re: Getting a Farmall A to fire in reply to rpbat, 03-31-2013 18:41:10
The points are getting power from the negative coil terminal. If Johns info is not helping you can google up some battery coil ignition diagrams. If the tractor ran before not much should need to be changing as far as the way it is wired.
rpbat
03-31-2013 19:03:38
 Re: Getting a Farmall A to fire in reply to dr sportster, 03-31-2013 18:52:40
I took his advice and I am not getting a spark from the coil, I am unsure what to do now, I know the coil is good because it was just replaced.
GVSII
04-01-2013 09:30:30
 Re: Getting a Farmall A to fire in reply to rpbat, 03-31-2013 19:03:38
You are in the dark here. Heres what to do.Enlist the physical help of a compatent tractor mech.
dr sportser
04-01-2013 14:37:04
 Re: Getting a Farmall A to fire in reply to GVSII, 04-01-2013 09:30:30
Exactly .He is starting to make incompetent statements, like I believe I have no power. TEST IT !
dr sportster
03-31-2013 19:10:30
Okay now go to step B of Johns chart and remove the cap check point gap and follow the next step.
dr sportster
03-31-2013 18:46:13
The coil has power the points trigger the coil . Use John T's page he posted the link to I just read it and have read it before. It should get you to where you want to go.
