TractorLinks.com
Tractor Talk Discussion Forum
Re: Getting a Farmall A to fire
rpbat
03-31-2013 17:54:21
I refered to John T's advice
The first step was
"To see if it happens to be a cap n rotor problem and to see if at least the coil is firing, remove the coil wire from the distributor (leave coil end intact) and place its bare end to within 1/8 inch from tractor iron, turn her on n crank her over, and see if she jumps that gap with a good visible blue spark?????? If so but the plug wire ends (from wire end to 1/8 inch to frame) or the plugs themselves donít fire, its a cap n rotor or plug wire problem. If the coil wire isnt even sparking, see below."
I could not get a spark between the coil wire and tractor iron.
dr sportster
03-31-2013 18:02:36
 Re: Getting a Farmall A to fire in reply to rpbat, 03-31-2013 17:54:21
How come I have to type my name every time. Okay anyway he is referring to the secondary or "spark plug thickness wires " when he is telling you to do that test . Check a wiring diagram and make sure the points { smaller guage] wire goes to the negative side of the coil. If I'm thinking backwards John or Old will yell at me. I did not read Johns Troubleshooting guide.
