Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: Getting a Farmall A to fire
rpbat
03-31-2013 17:38:21
Now im thinking I have a distrubuter because there is a 12 volt coil that sits above the distributer.
rpbat
03-31-2013 17:39:04
 Re: Getting a Farmall A to fire in reply to rpbat, 03-31-2013 17:38:21
It's round
This post was edited by rpbat at 17:39:31 03/31/13.
dr sportser
03-31-2013 17:43:10
 Re: Getting a Farmall A to fire in reply to rpbat, 03-31-2013 17:39:04
You have a distributor. Refer to John T's advice. On a normal Farmall A the mag is a self contained ignition . When yours was converted to twelve volts someone probably put a distributor on it. SEE JOHN T .
rpbat
03-31-2013 17:54:21
 Re: Getting a Farmall A to fire in reply to dr sportser, 03-31-2013 17:43:10
I refered to John T's advice
The first step was
"To see if it happens to be a cap n rotor problem and to see if at least the coil is firing, remove the coil wire from the distributor (leave coil end intact) and place its bare end to within 1/8 inch from tractor iron, turn her on n crank her over, and see if she jumps that gap with a good visible blue spark?????? If so but the plug wire ends (from wire end to 1/8 inch to frame) or the plugs themselves donít fire, its a cap n rotor or plug wire problem. If the coil wire isnt even sparking, see below."
I could not get a spark between the coil wire and tractor iron.
dr sportster
03-31-2013 18:02:36
 Re: Getting a Farmall A to fire in reply to rpbat, 03-31-2013 17:54:21
How come I have to type my name every time. Okay anyway he is referring to the secondary or "spark plug thickness wires " when he is telling you to do that test . Check a wiring diagram and make sure the points { smaller guage] wire goes to the negative side of the coil. If I'm thinking backwards John or Old will yell at me. I did not read Johns Troubleshooting guide.
Copyright © 1997-2015 Yesterday's Tractor Co.
