TractorLinks.com
Tractor Talk Discussion Forum
Re: Getting a Farmall A to fire
John T
03-31-2013 17:18:02
From your original post it sounded like it was a battery powered coil ignition (to which I posted a Troubleshooting Procedure), now you say its a Mag?? If its a Mag all a kill switch does is to provide a frame ground connection (via a kill switch) when turned OFF/Stop but its open (NOT to ground) when On/Run. As long as the mag (if kill switch terminal equipped) isn't grounded it can fire
Most common problem on Mags is the points are burned pitted or corroded which a good clean/buff/polish or use of a points file may cure
John T
rpbat
03-31-2013 17:33:53
 Re: Getting a Farmall A to fire in reply to John T, 03-31-2013 17:18:02
I think that it maybe a distributer and not a mag because it was converted to 12 volt system. How can I tell if this is a mag or a distributer.
