TractorLinks.com
Tractor Talk Discussion Forum
Re: Best way to transport a plow attached to an AC WD?
Bob Bancroft
03-31-2013 12:12:08
Since the WD only has one lever, (unlike the D series) it has to do everything. To operate draft control("traction booster") the lift lever will set the draft/depth. Depending on how the linkage is adjusted, it could be very difficult, to impossible to get it to work properly with hold position enabled. If you're not utilizing draft control, then I suppose it doesn't matter. Many people are very confused by the WD hyd. system settings. The same label that was on the battery box is in the operators manual. The D series pump is basically the same system, but controlled differently(two levers) and very few setting changes.
VicS
03-31-2013 13:00:56
 Re: Best way to transport a plow attached to an AC WD? in reply to Bob Bancroft, 03-31-2013 12:12:08
Also if the springs are still on the upper links they will unhook if the snap-coupler unhooks for some reason. If you wire them, you are asking for trouble. I have a neighbor with a nasty scar on his back from that happening. He had just wired one side, thought if had wired both sides would have killed him. Vic
Will Herring
03-31-2013 13:30:35
 Re: Best way to transport a plow attached to an AC WD? in reply to VicS, 03-31-2013 13:00:56
Yeah the snap coupler and bell seem to be in good shape and are not loose, and the springs are still on the two snaps so that they will open and close.
I assume by wired you mean that they are wired on and do not "open" any more?
VicS
03-31-2013 17:33:02
 Re: Best way to transport a plow attached to an AC WD? in reply to Will Herring, 03-31-2013 13:30:35
Yes that is what I meant. Vic
VicS
03-31-2013 17:31:24
Yes that is what I meant. No worry if the top couplers are spring loaded.
