TractorLinks.com
Tractor Talk Discussion Forum
JD 4240
Bruce Bushnell
03-31-2013 09:43:16
I started my 4240 yesterday and heard a clicking noise up by the radiator. Replace waterpump last season. Shut it off and the balancer seemed tight. I wobbles a little, but I don"t know what is acceptable. After the tractor warmed up I couldn"t hear the noise. Any suggestions
JD Seller
03-31-2013 12:11:03
 Re: JD 4240 in reply to Bruce Bushnell, 03-31-2013 09:43:16
I agree with Tx Jim that it is more than likely the hydraulic pump drive coupler. If you have caught it in time all you will need is the new isolator bushings.
Just reach in and see if you can rock the pump coupler back and forth. If you can move it at all it is bad. Just remove the clamp bolts and nusts. The two halves will come right off. I just take a sharp chisel and cut the bushing paralell to the shaft. They are just a type of plastic. If the pins have not worn the coupler halves than just install the new bushing. Then clamp the two halves of the coulper dive back together and you done.
DaveH IA
03-31-2013 12:56:44
 Re: JD 4240 in reply to JD Seller, 03-31-2013 12:11:03
just to add to JD good advise-- check the 2 bolts that clamp the cast coupler on the pump drive shaft and check to see it tightens down on the shaft-- the splines will sometimes wear
Tx Jim
03-31-2013 09:51:53
Balancer should be alright if rubber is good. Noise might be hyd pump coupler.
Texasmark1
04-01-2013 06:03:22
 Re: JD 4240 in reply to Tx Jim, 03-31-2013 09:51:53
+1 If it is, it will quit soon after you start up. A couple of revs of the throttle will aid in getting your answer.
If it is, replacing the rubbers is no big deal; maybe 30 minutes.
Mark
Bruce Bushnell
03-31-2013 13:20:27
I grabbed the coupler and couldn't move it and like I said the noise quit after a short time
Tx Jim
03-31-2013 13:37:44
 Re: JD 4240 in reply to Bruce Bushnell, 03-31-2013 13:20:27
I'll still bet the bushings are worn if they haven't been changed lately.
R45822 BUSHING ADD 2.21 USD 8.84
This post was edited by Tx Jim at 13:41:12 03/31/13.
Bruce Bushnell
03-31-2013 13:59:27
 Re: JD 4240 in reply to Tx Jim, 03-31-2013 13:37:44
I've only had it for a year no telling if they have ever been changed. I'll take it apart and see. Thanks Bruce
JMS/.MN
03-31-2013 17:35:38
 Re: JD 4240 in reply to Bruce Bushnell, 03-31-2013 13:59:27
New bushings are round. Worn are often egg-shaped. Had one JD without the lock nuts on the back side (bolts thread into the opposite coupler half.) Make sure you have them.
Bruce Bushnell
03-31-2013 19:59:28
 Re: JD 4240 in reply to JMS/.MN, 03-31-2013 17:35:38
Thanks wil check
