Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: My homemade dump trailer (pics)
Greenday
03-21-2013 04:42:43
If you would remove the ring gear off of the carrier in the differential then reassemble you will find it will make a big difference on how easy it will pull since it is not having to spin the pinion gear. Looks awsome! Nice job! Dave
ss55
03-21-2013 10:33:00
 Re: My homemade dump trailer (pics) in reply to Greenday, 03-21-2013 04:42:43
This may be a dumb question. With full-floating axle like that, the wheel bearings are on the outside of axle housing, the axle shafts do not carry any weight, only torque. Could you remove both axle shafts and the differential assembly without affecting the wheels or the brakes? That would reduce the total weight by 100 to 200 pounds (all of it unsprung weight), elliminate the friction of back-driving the pinion gears, and reduce the rotating inertia in that axle.
New sheet metal covers on the end of the hubs and over the pinion mounted hole would still be needed to keep dirt out of the wheel bearings.
Bryan iniowa
03-21-2013 05:01:27
I usually just pop the spider gears out . quick n easy .
Copyright © 1997-2015 Yesterday's Tractor Co.
