Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: OT Mazda Tribute AC
[Return to Forum]
FL Mark
03-16-2013 12:32:29
67.233.176.141
My wife"s 2001 Mazda Tribute with 200,000 miles has leak in hose coming off compressor. We are hoping the transmission holds up a few more years and we want to keep this car as long as possible. I will replace the accumulator while I am at it. Should I replace compressor while I have the AC opened up? What else should be replaced on AC system? Should all hoses, orifice tube, and condensor be replaced? Local parts store lets customers use a vaccum pump to get all of the moisture out of the system when finished. Is vacumming the system necessary? This car is the same as a Ford Escape if any of you have experience with those. Thanks for any information you can give me.
[Reply]   [No Email]
bjb in Tx from Ne
03-18-2013 05:45:32
147.1.234.165
Re: OT Mazda Tribute AC in reply to FL Mark, 03-16-2013 12:32:29
Be careful, when I tried to replace my compressor and one line last fall, the all the aluminum fittings were seized and striped. I ended up replacing the WHOLE system. You might want to have a professional shop work on it so they can replace the fittings if necessary.
  [Reply]  [No Email]
FL Mark
03-16-2013 17:53:16
67.233.176.141
Thanks for the replies. I am going to replace the hose assembly with the leak, accumulator and orifice tube. Does oil need to be added to the system? I saw online to add about 3 ounces of PAG oil. Does the oil come in an aerosol can like the R134a? How else does the oil get added if not the same way as refrigerant? I also need to get a spring lock tool to disconnect the lines. If I buy the parts online, I may get a vaccum pump from Harbor Freight and hope it works ok.
  [Reply]  [No Email]
evilboweivel
03-16-2013 15:16:18
75.185.40.180
orfice tube
dryer
vacumn down and hold for 1 hour
good luck
  [Reply]  [No Email]
glennster
03-16-2013 14:24:18
99.90.9.201
considering the mileage, i would just replace the leaking line. a/c parts get spendy, and its a roll of the dice how long any of the components will last. after you have the system open, i generally pull a vaccuum on them for about 45 min to an hour. then hold the vaccuum for another half hour or so to check for leaks before re-charging. you may want to shoot a little leak detector dye in there when you charge it, in case there is a leak. napa sells the kit for about 20 dollars, has the dye shot, a pair of yellow glasses and a u/v pen flashlite to check for leaks.
  [Reply]  [No Email]
rabbit
03-16-2013 13:26:44
207.241.137.116
Anytime you have a system open, it is absolutely necessary to vacuum it down before adding freon.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
