Yesterday's Tractor Co.
Shop Now View Cart
Tractor Talk Discussion Forum
Re: OT 97 Dodge Ram
03-16-2013 07:08:31
PCM is bad? Before you check into a PCM more diagnostics need to be done from what you have posted. You need to know if they checked power and ground to the PCM and check affected circuits. No fire could be crank sensor, Hall effect in dist."etc". Don't put a used one on it until all no start checks have been done or you may be out the money. A scan tool WILL NOT tell you if it needs a PCM unless it has a watchdog circuit code in the controller. Hope this helps. Gerard
03-16-2013 07:10:00
 Re: OT 97 Dodge Ram in reply to ASEguy, 03-16-2013 07:08:31
Should have said do not put a used one in. Reman or new only and only after diagnostics are done. Sorry.
