Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: Marvel Schebler Choke Issue
old
03-12-2013 13:29:03
Could be one of a few different problems. Your air cleaner may need to be serviced and if the cup is empty it can cause that. #2 fuel flow maybe to slow. Does it have the incorrect in line filter in the line if so throw it away that could be the problem. Next pull the carb drain plug out of the bottom of the carb and let it flow for a few minutes. Catch the gas so as to look for water/dirt etc. You need a good steady flow there. Next open up the main jet. You should be able to open it up to the point you have black smoke. If you can open it up so far that you can remove it and still run the carb is clogged up and need to be rebuilt
Copyright © 1997-2015 Yesterday's Tractor Co.
