3020 injector pump rebuild cost
Just had the pump and injectors all rebuilt on my 67 jd 3020. Billed at 938 dollars. Does this sound reasonable? I have no shop, so I sent it to a local mechanic for him to tear down and he sent the pump and injectors off to a so far unknown 3rd party. I was quoted less than 1k as an estimate, bill was 1500...
For the pump and injectors,yes,sounds reasonable. It's been a while since I've had a pump done,last one was off a 4040,pump alone was over $800.
Should have sent it into these guys. They do good work and are pretty reasonable. They got my Bosch going when nobody else would touch it.
injector pumps
Hi If that's a Roosa Master pump you did ok.
I had one of those and injectors done 8 years ago for an Allis and it was $1200 i think from memory and the cheapest quote.
other guys wanted 15-$1700. There are some real expensive parts like the cam ring and stuff in there if they needed changing.
Most guys don't have the stuff in a regular repair shop to do them properly. They go to the fuel pump specialists,with all the pressure and calibration rigs/ and injector testers.
Regards Robert
Brother had his rebuilt last year it was $700. Good friend retired has shop in back yard thought it was kinda high usually about 1/2 that.
Ron
Thanks guys, it does run a lot better now. Virtually no smoke when i drove it home, have to be careful when i use the foot throttle now, it sets me back in the seat compared to before.
