I'm almost finished getting the tractors factory electrical system restored on my 1566 - doing all used parts - everything works good now except my air filter gauge.
I've put on a new sending unit and replaced both the inner and outter filters and replaced the air sensor sending unit.
I had to guess about the gauge connections however cause the original had been removed by the former owner and he installed an aftermarket water sensor there - which I've removed.
But, I've only started the tractor briefly- mostly cause its cold and also because most of the sheet metals still from the clutch replacement but when I've started it - it stays on red.
Any ideas on that? Does it need to be running to be on green?
