1000 pto 3pt discmower
You must be thinking about a mower conditioner as all the disc mowers you see are 3pt how else do you hook them up as they dont have any wheels.
I have my 3 pt disc mower mounted on a caddy. IMHO it's the only way to fly. Back up to hitch,drop pin in the hole then attach pto & hyd hose and off to hay field.
I have been wondering the same thing. If you could figure out how to change the belt pulley config. you could make it work that way.
(quoted from post at 08:07:53 03/04/13) I have been wondering the same thing. If you could figure out how to change the belt pulley config. you could make it work that way.
Exception: Not all 3 pt disc mowers are belt driven. Krone is one example.
My pottinger disc mower conditioner is a 10 ft'er and can be had with 1000 rpm gear box.
Most disk mowers ARE 3pt hitch....and most disk mower conditioners are pull type.
Of course, the larger disk mowers can be had pull type, and some companies like Pottinger built 3pt disc mower conditioners..
Pottinger is made in Austria I think? They are getting popular in the
US as butterfly mowers, that is one in the front and one like mine
on both sides in the rear. Their rotary rakes and forage
chopper/wagons are quite popular.
I would love to have one of the front mounted ones and the tractor
to run it.
