Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: model A tractor
[Return to Forum]
Kevin Holt
02-21-2013 17:10:45
216.241.198.38
my model A is over heating, but im pretty sure the
radiator has flow. there isnt a pump so i cant
figure out why it would be running 210.
[Reply]   [No Email]
Kevin Holt
02-22-2013 15:42:18
216.241.198.38
Re: model A tractor in reply to Kevin Holt, 02-21-2013 17:10:45
wow guys thanks for the comments. that was extremely helpful. to clear things up, it is a john deere model A, the model with no water pump. I think it might be low on fluid. thanks again. you guys are awesome. and more important, you guys are really smart!
  [Reply]  [No Email]
El Toro
02-22-2013 06:55:52
108.3.218.181
Touch the bottom hose lightly to see if it's hot.
You may not be getting circulation through your radiator. Tubes could be plugged. Hal
  [Reply]  [No Email]
Blackhole49
02-22-2013 06:36:43
71.227.8.100
I don't run my M in the winter, but in the summer it is always at +-210 no matter what the temp is. I don't know why they put the temp sensor at the hottest point. I do know it never over heats and the bottom hose you can wrap your hand around and keep it there.
  [Reply]  [No Email]
Mark-Ia
02-22-2013 02:19:50
207.177.117.7
Pretty normal for a John Deere A with the thermo=syphon system to run that hot. No worries here.
  [Reply]  [No Email]
gene bender
02-21-2013 19:33:07
67.55.226.151
Problay blocked where the sleeve enters the blosk at the bottom those hole are small where the coolant returns to the radiator. Mite drain and fill with vinegar to see if the vinegar will loosen up the residue. Next would be remove radiatoe and lower housing so you can use compressed air and wate to clean those holes.
  [Reply]  [No Email]
James Lieb
02-21-2013 19:05:41
75.249.77.58
Check to see if your timing is correct,sounds like it might be retarded.
  [Reply]  [No Email]
John B.
02-21-2013 17:43:03
38.114.64.177
Yes you need to let us know what make "A" tractor you have so some of us can better help you.
I've seen on Farmall A tractors the sleeves were surrounded by debris buildup over 40+ years and it would run hot due to this that and not having a water pump.
  [Reply]  [No Email]
Rickieblue
02-21-2013 17:16:18
65.37.20.241
I am assuming John Deere A...correct?
  [Reply]  [No Email]
Greg K
02-21-2013 17:15:31
75.107.96.58
John Deere, IH, Allis? what kind of model A? Maybe it doesn't have the right anti freeze mix and not circulating.
  [Reply]  [No Email]
Greg K
02-21-2013 17:17:09
75.107.96.58
Re: model A tractor in reply to Greg K, 02-21-2013 17:15:31
I meant maybe it is frozen into ice.
  [Reply]  [No Email]
Rickieblue
02-21-2013 17:14:30
65.37.20.241
Make sure the system is full, otherwise it won't thermosiphon..thus..no flow...make sure the louvers are open, and of course make sure the fins are clean so they will flow air. Really it is a pretty simple system and not subject to problems usually.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
