| Tractor Talk Discussion Forum |
Topic: 74 ford tranny
[Return to Forum]
| Author |
[Modern View]
| molinebob
02-21-2013 16:58:02
69.89.205.152
I have a 1974 Ford F250 4x4 with a snow plow on it, put the plow on last year, has a 360 with the C6 trans, question is sometimes it goes in gear right away others i have to rev it way up then it goes, and after act like nothing ever was wrong, going down the highway it works and shift as it should, if i run it for along time it works without problems, unless i let it idle for a long period of time in park then it acts up for the first time going into forward, no probs with reverse at all, just forward, if I manually shift it to low and up it still does it....replaced the fluid and filter and still does it...fluid was not burnt at all..has me stumped as to what could be wrong with it...Thanks for any and all help..Bob |
| VernMI
02-22-2013 04:38:11
209.86.226.27
Re: 74 ford tranny in reply to molinebob, 02-21-2013 16:58:02
| Teflon seal rings have trouble energizing when cold. They rely on pressure behind them to push them out against the seal surface and in your case the oil flow is going around them until there is enough flow to build pressure to push them out against the seal surface. Higher engine speed increases the oil flow until they finally energize. Teflon seal rings have very little "memory" so they don't spring into place like a cast iron ring. Some seal rings are solid one piece while others have "scarf cut" ends. New seal rings will probably fix the problem because they are slightly more pliable and don't have the wear that is on the old rings. |
| ASEguy
02-22-2013 04:30:47
68.186.162.134
| You don't have problems in reverse because the high reverse clutch is't involved. If no problem in second the kickdown band is good enough too. Sounds like your problem is the forward clutch assembly seals. When they are cold they shrink and allow for pressure loss. When they warm a bit they swell and seal better which is why it's ok after start-up. Gerard |
| Allan In NE
02-22-2013 03:16:06
148.66.88.254
| | Those C6s are bad about that. Since you have to pull the transmission out to replace the torque converter anyway, might as well go ahead and overhaul the beast while it's out. Allan |
| davpal
02-22-2013 01:07:10
216.93.96.48
| I had one that did that and the guy I had rebuild it said it had bad piston rings on the pump letting the pressure escape. It would only do it when I backed out of the driveway and put it in drive, it would hesitate before going which I found to be very irritating and dangerous. In other words you have an internal leak and it needs a rebuild kit installed. |
| 504
02-21-2013 20:35:47
199.127.54.155
| Check the front cab mounts just about where your feet would be. The stamped steel cab frame will rust out and let the cab drop just enough for it to set on the steering column, when that happens, it really can mess with the column shifter. And yes, Type F fluid only |
| ericlb
02-21-2013 19:03:25
70.41.96.39
| like others said what kind of fluid did you put in it, i believe 74 still used type F fluid, but you need to check that also the linkage, if sloppy [ bushings worn on the linkage rods], occasionally it may not be going all the way into D but hanging up a little in nutural |
| Notjustair
02-21-2013 17:22:04
174.253.128.91
| | Not familiar with that trans, but with others that can be because it isn't building enough pressure to shift. Could be internal seals going. I had one doing that and put Lucas for transmissions in it and it turned it right around. Made that trans work for many more miles. It won't fix it, but if you need 5000 miles out of it you might be in luck. |
| Dick W.
02-21-2013 17:11:18
174.54.58.169
| Try 1 quart over the full line. A lot of C6 trans do better with the extra quart. What oil did you refill it with? Is the kick down rod connected and operating properly? Its been too long to remember how that all works without seeing one! Does it have a vacuum modulator on the right rear corner? Are the cooler lines kinked too tight too allow good oil flow? Enjoy your old Ford, we updated last year after rust ate our 85 F-250 4x4. |
| oldtanker
02-21-2013 17:05:22
66.228.255.239
| Pull the vac line off the modulator and check for tranny fluid in the vac line. If it's there replace the mod. Other than that You may have a problem with the vlave boby.
Rick |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
