Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: O.T. Steel automotive wheels?
[Return to Forum]
JF in CT
02-21-2013 16:08:55
71.88.46.81
I’m looking at replacing my wife’s car next year. Seems that these days most new cars come with aluminum wheels which I would assume are for weight/fuel savings. For every car owned I’ve always kept a set of snow tires mounted on separate steel wheels. Mostly because they are cheaper and I don’t relish the idea of sliding on ice and smacking a pricey aluminum wheel into a curb. When I look at the specs of a new car I also research substitute wheels and can’t find any for a 5 x 105 mm pattern (plenty of aluminum ones however). Are steel wheels dead or does anyone know a source?
Jim
[Reply]   [No Email]
James22
02-22-2013 10:15:42
207.179.221.10
Re: O.T. Steel automotive wheels? in reply to JF in CT, 02-21-2013 16:08:55
Steel is available but I was told they are about as expensive as aftermarket alum. I bought a new low frills truck that had steel rims. Wanted to buy four snows and steel rims for the winter. Tire dealer said buy alum rims and we will switch tires. Also bought sensors and straps from Rock Auto. Ford dealer price for straps/sensors and factory steel rims are unreasonable. Tire swapped tires and installed the four new sensors on the new alum rims. So far everything works.
  [Reply]  [No Email]
Mike M
02-22-2013 07:18:04
24.140.0.120
Snow tires on 4 extra rims with pressure sensors are the way to go. Regular all season tires are a joke !
I am learning the hard way. I tried just 2 snow tires on the front of my little car. It went good ,stopped good,but if you turned a corner as in town going slow the rear of the car would slide around !!!! Tried some weight no help.
So I got 2 more snow tires for the rear. Now it goes good. So after useing 2 extra rims with no sensors and not having extra rims for the others and had my tires swapped around on my good rims that are now getting bad from poor tire mounters and road salt.My TPMS light can't make up it's mind. I now see that trying to save some money is actually going to cost me more then if I'd of just bought a snow tire package from tirerack.com.
I also wish I'd of bought the steel rim version of this car too. I'm not an alum. wheel fan either. Many tires shops still don't have good equipment to mount and dismount tires without scratching them all up and then they don't have the proper balance weights or even stick on ones.
  [Reply]  [No Email]
Pops1532
02-21-2013 23:15:33
68.58.114.55
You'll not only need to find the correct bolt spacing , but the correct rim width and back spacing, and of course diameter. A wrecking yard will have a Hollander interchange manual or software that should show if there are any OEM steel wheels that will fit your application.
  [Reply]  [No Email]
Rich_WI
02-21-2013 19:16:00
50.50.77.31
http://www.discountedwheelwarehouse.com/Vehicle_Bolt_Pattern_Reference.cfm
That site will have all the vehicles and their bolt spacing. Just click on each different manufactor and make a list of cars that have the rims you are looking for. When you find a couple cars with the same rim bolt spacing pattern as you are looking for, google that car to make sure they have full sized spares, then take a trip to the junk yard. Or craigslist. I got all my spare steelies from there, usually 1 or 2 at a time. Its a little more of a pain that way but the price for singles is usually very low.
Steel wheels are on the way out but so are full sized spares. Makes getting a second set of rims kinda hard.
  [Reply]  [No Email]
Hobo,NC
02-21-2013 18:58:04
98.17.83.140
Re: O.T. Steel automotive wheels? in reply to Goose, 02-21-2013 16:08:55
I am not buying into your statement but have no info to discredit it so you may be dead right,,, I believe its a strength issue... The way they make wheels now with so much offset steel wheels catch ELL!...
  [Reply]  [No Email]
John B.
02-21-2013 17:59:33
38.114.64.177
Get ready to part with some money if you do find steel wheels which I doubt but the price to put Air Pressure Sensors in them. All new cars are required to have them. I haven't heard anyone having an extra set of wheels and tires for snow for the past 45 years. With front wheel drive vehicles now days I wouldn't worry about an extra set of snow tires.
  [Reply]  [No Email]
Adirondack case guy
02-21-2013 19:57:26
74.69.160.79
Re: O.T. Steel automotive wheels? in reply to John B., 02-21-2013 17:59:33
I guess you don't live in the great North East. Many still run studded snow tires here. I have snows front and back on the wifeys 2wd ranger. It is a lot harder to stop and steer than to keep moving, and not get stuck.
Loren, the Acg.
  [Reply]  [No Email]
charlie n
02-21-2013 17:00:12
96.35.24.196
It's probably got 17 or 18 inch wheels.Good luck.
  [Reply]  [No Email]
bobs old iron
02-21-2013 16:51:14
97.122.253.138
just get one of those wheel plastic gauges from local parts shop that measures bolt pattern, then you can go to local bone yard, or c-list to look for steel wheels,, as stated, its a fuel/weight saver from mfgr, and cheaper then steel...
  [Reply]  [No Email]
Pitch1
02-21-2013 16:44:03
66.66.18.32
Yep that was what they wanted,she passed on em and we just mounted her studs on the alloys. Cruze comes with steel on the base model.
  [Reply]  [No Email]
Pitch1
02-21-2013 16:33:56
66.66.18.32
I always buy snows mounted steel from tire rack when I get a new car. I actually checked with GM for my daughters 2012 Cruze, they wanted about 90 per if I remember correctly.
  [Reply]  [No Email]
JF in CT
02-21-2013 16:38:57
71.88.46.81
Re: O.T. Steel automotive wheels? in reply to Pitch1, 02-21-2013 16:33:56
For steel? Are you saying they exist for that pattern? (Actually I was considering a Cruze)
  [Reply]  [No Email]
MarkB_MI
02-21-2013 16:27:17
75.219.66.134
Steel wheels are pretty much dead in the US. One of the main drivers is sound: steel rims make a lot more noise than alloy rims, and car buyers today expect a quiet car.
  [Reply]  [No Email]
Retired Farmer
02-21-2013 17:52:57
207.200.116.74
Re: O.T. Steel automotive wheels? in reply to MarkB_MI, 02-21-2013 16:27:17
Just too bad they don't make a quiet car. I been in a few newer ones and you can't even hear yourself think.
  [Reply]  [No Email]
RayP(MI)
02-21-2013 16:19:18
207.241.137.116
Salvage yards? Those guys would probably know what might fit.... Many cars used to cross wheels.
  [Reply]  [No Email]
504
02-21-2013 20:42:30
199.127.54.155
Re: O.T. Steel automotive wheels? in reply to RayP(MI), 02-21-2013 16:19:18
Ask at your local body shop, they will have a suppler of reman AL wheels, probably cheaper than new steel.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
