TractorLinks.com
Tractor Talk Discussion Forum
Re: OT-silverado brake issue question
bgud
02-21-2013 10:46:57
Hi Ray couple of questions for you first did you put pads and rotors on both axles and second does this happen when you first apply the brakes or when your almost stopped
Ray
02-21-2013 11:32:42
 Re: OT-silverado brake issue question in reply to bgud, 02-21-2013 10:46:57
The original front pads looked like new,so they used them over.Front and rear rotors were replaced.It did this before the brake job.It only does it at slow speed,like pulling up to a light or just about stopped.
bgud
02-21-2013 11:57:47
 Re: OT-silverado brake issue question in reply to Ray, 02-21-2013 11:32:42
The problem is rust build up under the front abs sensors. You will need to remove the sensors and clean the rust off the hubs. Make sure you put some grease on the sensors and hub mounting surface to prevent it from happening again.
