TractorLinks.com
Tractor Talk Discussion Forum
I'm looking for a 4010/4020 gas engine
JohnDeereJimOhio
02-17-2013 13:19:05
I'm looking for a 4010/4020 or 7700 combine gas motor doesn't need to be running. I need oil pan to valve cover and that's it no intake or exhaust.. This is going in a pulling tractor and I'm stripping all that parts if anyone is I retested in trading, or straight up cash deal.. Please send an email or I can email you my number..
DoverFarmer
02-18-2013 05:26:59
 Re: I'm looking for a 4010/4020 gas engine in reply to JohnDeereJimOhio, 02-17-2013 13:19:05
i have a complete 1966 gas 4020 motor recently pulled for a diesel. engine has 5200 hours and is all original.
JohnDeereJimOhio
02-18-2013 06:20:31
 Re: I'm looking for a 4010/4020 gas engine in reply to DoverFarmer, 02-18-2013 05:26:59
Where are u located? Have a number I can reach u at?
DoverFarmerannemz
02-18-2013 06:39:15
 Re: I'm looking for a 4010/4020 gas engine in reply to JohnDeereJimOhio, 02-18-2013 06:20:31
I am about 30 mi. west of toledo and 10 mi. north of mi/oh line #517-436-6470
DoverFarmer
02-18-2013 05:30:17
i have a 1966 4020 gas complete and running recently pulled for a diesel.
D-C-741
02-17-2013 17:13:13
I have 1 out of a 7700 Combine,Its Rebuilt & never put back in to the combine, do to other problems found while the engine was out.I am Near The Walkins Glen Race Track= out side of Ithaca,NY
JD2ACWD
02-17-2013 13:58:51
ebay has a couple
Jon Hagen
02-17-2013 13:57:45
I put a 105 combine engine in my 4020 about 15 years ago. Excellent running 2500 hr engine for $800. It has served me well since adding a powerful electronic ignition and getting rid of that rerdiculous oversize stock carb and replaced it with a smaller one from a 283 Minni Mo. No more smoke,Hard starting, fouled plugs or spitting, uses less fuel and much better low to mid rpm performance.
They also crank much better if you replace the way undersize 10MT starter with a twice as powerful 20MT.
Those engines are harder to find now, too old for most salvage yards and ones parked in the tree row for 10 years are mostly rusted up.
Bman
02-17-2013 17:05:09
 Re: I'm looking for a 4010/4020 gas engine in reply to Jon Hagen, 02-17-2013 13:57:45
So what carburetor did you use to replace the stock carburetor?
Jon Hagen
02-17-2013 17:17:58
 Re: I'm looking for a 4010/4020 gas engine in reply to Bman, 02-17-2013 17:05:09
One from a MM 283 engine in a model "U" tractor.
It needs a little die grinder work to fit the wider spaced mounting studs of the JD manifold and modify the throttle arm to match the JD linkage. The choke cable and air cleaner tube fits right up and fuel line adapts easily.
Makes a whole new tractor out of them once you get rid of that stinking big vacuum accelerator pump carb.
Fixerupper
02-18-2013 10:51:39
 Re: I'm looking for a 4010/4020 gas engine in reply to Jon Hagen, 02-17-2013 17:17:58
Jon, I have to sympathetically chuckle about the carb. On my 105 I finally plugged the vacuum hole that works the accelerator pump. Fuel economy was MUCH better and it idled fine. Downfall to doing this was I had to open the throttle very slowly. I'll remember your suggestion about the Minnie Mo carb. The combine is gone now but I still have the engine. Jim
Jon Hagen
02-18-2013 14:10:26
 Re: I'm looking for a 4010/4020 gas engine in reply to Fixerupper, 02-18-2013 10:51:39
I suspect JD used that overly big carb to maximize full rmp power, but it sure messed up the part throttle performance. Being most 4010-4020 gas tractors now never see much if any full power work, the smaller carb makes them a much nicer performing tractor.
I have not put mine on a dinamometer with the slaller carb, but I know it handles a 13X61 grain auger just fine in damp wheat. That is about a 100 hp load, so If it lost any power, it is not much.
Bman
02-17-2013 17:29:20
Thanks
88-1175
02-17-2013 13:54:46
why not modernize some.a 466cng would be a much better choice
The Red
02-17-2013 13:38:39
Call Bryant Combine of Bryant, Indiana. They use to have hundreds of old combines but I heard most got scrapped. Might still have engines around. 800-255-1071
Case Nutty 1660
02-17-2013 13:34:23
I know where a 105 gas is in Wyoming for sale
DeltaRed
02-17-2013 13:23:03
Find an old 105 gas combine.That is a 4020 gas...
JohnDeereJimOhio
02-17-2013 13:28:25
 Re: I'm looking for a 4010/4020 gas engine in reply to DeltaRed, 02-17-2013 13:23:03
I've checked all the local tractor junkyards and I'm not having any luck.
massey 333
02-17-2013 14:44:04
 Re: I'm looking for a 4010/4020 gas engine in reply to JohnDeereJimOhio, 02-17-2013 13:28:25
Did you try Genes Recyling at Utica onRt.4 and 224.?
casenut1
02-18-2013 17:27:00
 Re: I'm looking for a 4010/4020 gas engine in reply to massey 333, 02-17-2013 14:44:04
i think that is Attica.
massey 333
02-19-2013 15:29:52
 Re: I'm looking for a 4010/4020 gas engine in reply to casenut1, 02-18-2013 17:27:00
You right,I knew it was Attica and why Utica I don't really know.Been there 100 times and can do blindfolded so ????Thank you for catching it.
massey 333
02-17-2013 15:16:37
419-426-6452= Genes
