Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: OT Stihl saw
[Return to Forum]
Heyseed
02-17-2013 10:39:15
69.19.14.23
I have an older (17 years) Stihl that has always started fine and done a ton of cutting. The last two times out it will start fine, idles fine but would die when I gasses it. The air filter is clean and it has a pretty new plug. It did this yesterday, I cleaned the carb area off with carb cleaner, and blew any built up crud off with air gun. It then ran fine for the rest of the day. Today it started out fine but is doing the same thing again. It acts like it floods as soon as you squeeze the throttle and dies. But will start right back up and idle as long as I let it. Photos are what I cut with it yesterday After it acted up the first time. Thanks for any ideas on what to address.
I posted this on tool talk as well.
[Reply]   [No Email]
FBH44
02-17-2013 15:32:44
64.85.216.200
 Re: OT Stihl saw in reply to Heyseed, 02-17-2013 10:39:15
I have to clean out the muffler spark arrrestor screen, on my MS-180, or mine abslolutely will not run. use a propane torch, knock all the dust off, and fixed.
[Reply]  [No Email]
JayinNY
02-17-2013 18:05:38
198.228.200.48
 Re: OT Stihl saw in reply to FBH44, 02-17-2013 15:32:44
Or Throw the screen in the garbage, and you'll never have that problem again! I chuck the screen on all my 2stroke things, which is about 2 dozen pieces of equipment.
[Reply]  [No Email]
bill mart
02-17-2013 13:51:12
69.204.65.189
is that oak? bill
[Reply]  [No Email]
JayinNY
02-17-2013 14:02:15
198.228.200.37
 Re: OT Stihl saw in reply to bill mart, 02-17-2013 13:51:12
Looks like red oak to me??
[Reply]  [No Email]
John B.
02-17-2013 12:26:53
38.114.64.177
I would replace the gas cap along with the fuel line and fuel filter.
[Reply]  [No Email]
Mark Robke
02-17-2013 12:25:51
75.90.230.161
My 028 will do that from time to time. There is a screen on fuel inlet of the carb that clogs up. It is tiny , about the diameter of a dime or smaller. Usually I try to clean it and drop and lose it and end up replacing it. Costs maybe .50 cents.
Mark
[Reply]  [No Email]
JD Seller
02-17-2013 11:00:17
208.126.196.144
I would say start at the fuel filter in the tank. Just hook it with a small wire and it will come out the filler hole. While you have it out look the line over real well. They go bad with age and fuel.
[Reply]  [No Email]
ray(MO)
02-17-2013 10:56:57
76.8.147.9
Mine did that. I replaced the fuel line cause it was bad from this alcohol in the gas.
[Reply]  [No Email]
motorcraftman
02-17-2013 16:16:32
74.176.174.174
 Re: OT Stihl saw in reply to ray(MO), 02-17-2013 10:56:57
Speaking of Gas, I've lately switched to Pure NO Ethanol gas,in My 031AV Stihl May be My Imigination, BUT, It actually seems to Run better, is this possibly a reality? larry
[Reply]  [No Email]
JayinNY
02-17-2013 10:48:40
198.228.200.33
Check the low and high speed screws on the carb for proper adjustment, check fuel line filter in the tank. Has the saw been sitting long? Maybe dirty carb internally.
[Reply]  [No Email]
Mike (WA)
02-17-2013 10:41:39
174.31.209.196
Sounds like exactly the same symptoms as my 031AV- needed a new fuel line. They don't fare well with alcohol- get alcohol free gas for all your small engines, if you have it available somewhere in your area.
[Reply]  [No Email]
uncletom
02-17-2013 16:53:02
173.30.113.188
 Re: OT Stihl saw in reply to Mike (WA), 02-17-2013 10:41:39
I have an 031AV also. If it were my saw, i would turn out the low speed mixture screw about 1-8th of a turn. There are 2 mixture screws. The high and low. the low is a little lean.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
