Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: Re: More on well pump wire
[Show Entire Topic]  [Return to Forum]
MarkB_MI
02-17-2013 08:14:53
75.198.116.81
There are two ways to do it. One requires five conductors, the other requires only four conductors, but also a load center.
So in the first example, you hook up the well as before, then run a third "hot" and a neutral for the convenience outlet. The extra hot needs its own breaker back in the house.
In the second method, you'll run your pump wires to the load center rather than to the pump. You'll also need to run a neutral from the house to the load center. Then run the pump and outlet off different breakers in the load center.
In either case, the ground wire should be grounded locally in the pump house; I think tying it to the well pipe should do it, but you might want a separate ground rod as well. The ground and neutral are kept separate in the pump house.
[Reply]   [No Email]
John in la
02-17-2013 08:46:55
184.38.219.209
Re: More on well pump wire in reply to MarkB_MI, 02-17-2013 08:14:53
Thanks Mark
I will go with method two and put a sub panel at the pump house.
I understand keeping neutral and ground seperate at the pump house what I did not consider was grounding the green ground wire at the pump house.
Since I have a plastic well casing I will opt for the $12 ground rod and clamp.
I solved the problem with the Ditch Witch even though the clay is so packed it seems like we are digging into concrete. Problem is now my 26 yr old son and 25 yr old SIL may not speak to me for a week. You boys want water..... get to work.
  [Reply]  [No Email]
MarkB_MI
02-17-2013 09:11:48
75.198.116.81
Re: More on well pump wire in reply to John in la, 02-17-2013 08:46:55
Ha! I think I can guess who got the honor of operating the Ditch Witch.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
