Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: More on well pump wire
Kirk Grau
02-17-2013 07:30:49
Run back to the supply house/Lowes/Home Depot and pick up a 4 or 8 circuit load center, seems like it should set you back about $30 plus the breakers. Think of it like a little sub-panel and wire your circuits from there.
Others will chime in with other options, but this would be my approach. Gives a little future flexibility if you decide to wire a receptacle out there some day. I am assuming your pump controls are at the well if you are able to change power source as you are. If pressure switch is remote, might have to rethink.
Good Luck,
Kirk
John in la
02-17-2013 08:18:32
 Re: More on well pump wire in reply to Kirk Grau, 02-17-2013 07:30:49
Yes the pressure switch is in the pump house.
In the past I only had 220 out there (2 hots and a ground) and it was hard wired to the pressure switch. The breaker in the main panel protected the pump and all the wiring running out to the pump.
I guess I could have (should have) installed a A/C type disconnect box out there but never did.
Now that I am old enough to be installing stuff the kids will have to deal with I take a differant out look on how I do it.
A little sub panel with a 220 breaker for the pump; and a 110 breaker for the light; future receptacle sounds like the way to go.
buickanddeere
02-17-2013 11:06:43
 Re: More on well pump wire in reply to John in la, 02-17-2013 08:18:32
Good man for running a neutral. Too many people here still think a connection to ground is the same thing. The neutral wire out in the pump house is not supposed to have any connection with the ground. Ensure that there is not a bond screw in the neutral terminal block. A ground lug on the well casing and #6 bare copper up to the ground lug and green wire in the breaker box is good. Some jurisdictions also want a 10ft ground rod driven in and connected to the breaker panel as well. Not a bad idea if there is work being in or around the well casing.
