TractorLinks.com
Tractor Talk Discussion Forum
Re: Any 7.3 powerstroke experts on the board?
Brad Gyde
02-16-2013 20:20:59
Update for AScheele and others: Today I took the time to swap things around on the Injector Pressure Regulator, and I also tore apart and cleaned the fuel regulator mounted on the side of the filter housing, and pushed compressed air through the return line.
I am unsure which of these did the most help, or if it was a combined effort, but the truck now starts pretty good (got to crank just a little more than I like, but not to the point that it is what I would call it hard starting). When you get into the accelerator and let off it don't stall either.. Double bonus!
We went for a 7 mile joyride in the old girl, and the oil level is right where it was previously, so i think the fuel in oil problem is solved, but I do believe I in fact have a bad injector, as at an idle it has what can best be described as a "miss", so I guess the injectors will get pulled again and sent to be tested.
Brad
AScheele
02-16-2013 23:19:54
 Re: Any 7.3 powerstroke experts on the board? in reply to Brad Gyde, 02-16-2013 20:20:59
Im glad its starting better for you. but before you jump into getting injectors removed and tested, make sure all the wiring harnesses under the valve covers are good. i had to replace all of mine, and two of the connectors on the main wiring harness when i first got it.
