Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: Re: Tractor stalls only when sudden load is applied?
[Show Entire Topic]  [Return to Forum]
rrlund
02-16-2013 17:38:58
207.241.137.116
The 1550s don't have an accelerator pump. They're the old Marvel carb.
Does it idle OK? For some reason I always have to keep mine choked a little. The 1600 is the same way. Is yours better after it warms up some?
I had trouble with mine idling rough and it was sucking air where the intake manifold bolts to the exhaust. You might check for leaks there and for intake leaks where the manifold mounts up to the head.
[Reply]   [No Email]
Jerry/MT
02-16-2013 20:40:57
206.183.116.145
 Re: Tractor stalls only when sudden load is applied? in reply to rrlund, 02-16-2013 17:38:58
If it has a Marvel-Schebler carb it has an acceleration well that supplies extra fuel when the throtle is opened up quickly. Either your float level is low, OR the carb is adjusted too lean, OR you have an air leak around the carb metering system. I"d try turning up the mixture first to see if that helps.acceleration.If it doesn"t, check for an air lleakaround th throttle shaft, the carb to manifold interface, or the manifold to cylinder head/block. Look for rust holes or cracks in the manifold itself. Spraying starting fluid (Carefully because it"s very flamable) around these areas will cause the engine to speed up when you hit the leaky areas.
You"ll also need to check the timing and the advance for functioning as well as the spark(Fat and bluish-white).
[Reply]  [No Email]
rrlund
02-17-2013 05:23:28
207.241.137.116
 Re: Tractor stalls only when sudden load is applied? in reply to Jerry/MT, 02-16-2013 20:40:57
Instead of starting fluid,I put a hose on a small propane torch,then don't light it,just turn on the propane. Move the hose around and it will rev up if the leak sucks it in.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
