Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: Tractor stalls only when sudden load is applied?
JD Seller
02-16-2013 16:35:10
It could be several things. The most common one is that the carburetor is set too lean. All you would need to do is open the load valve/high side a little. A more unusual one would be a bad coil. I had a Oliver 1650 that was doing the dieing under sudden load and it was the coil on it.
Brian G. NY
02-16-2013 18:59:15
 Re: Tractor stalls only when sudden load is applied? in reply to JD Seller, 02-16-2013 16:35:10
I believe JD is on the right track; my WD Allis will stumble like that in the cold weather but if I open the main jet a 1/4 turn or so, it works fine.
In the summer I can lean it back up again.
Copyright © 1997-2015 Yesterday's Tractor Co.
