Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: Block and tackle or something else?
[Return to Forum]
Zachary Hoyt
02-16-2013 15:45:04
50.122.169.86
I have these mystery objects that have been hanging on the wall of my building since I bought them at an auction a few years ago for $10 or $20. I bought them thinking that they were a block and tackle but they don't seem to be the more I look at them, since there is no ring on the side opposite the hook. I am starting to wonder if they were something off a machine of some kind. The pulley wheels are 8" in diameter and it looks like they would take a 1/2 or 5/8 rope or cable at a guess. Each one weighs 45 pounds or so. If anyone knows what these are or what I should do with them I would appreciate any advice.
Zach
[Reply]   [No Email]
Jim in Ma.
02-17-2013 08:02:28
72.70.122.174
 Re: Block and tackle or something else? in reply to Zachary Hoyt, 02-16-2013 15:45:04
That is a nice set of rope/cable falls.
The more pulleys you have = more Pull (power)
[Reply]  [No Email]
Zachary Hoyt
02-17-2013 06:50:42
50.122.169.86
Thank you all very much. Each piece has two pulleys on it, I just turned them so both views could be seen in one picture. I am sure they are not snatch blocks since they have two pulleys and do not open easily. I will look for a rating on them.
Zach
[Reply]  [No Email]
Dan Richardson
02-17-2013 05:42:19
67.236.13.198
Let"s get the kinks and knots out. Rope is twisted wire. Cable is electrical wiring. The only rope on a ship is the bell rope, the bolt rope, and another one I can"t remember.
[Reply]  [No Email]
John Fulton
02-17-2013 07:41:57
67.142.162.22
 Re: Block and tackle or something else? in reply to Dan Richardson, 02-17-2013 05:42:19
The other rope? Why "rope-yarn Sunday" of course. LOL!
I was a seaman on a Destroyer-Leader for a while, sea detail on #6 line aft. It was a 6" wire rope, greasy and black. We always had to be in undress whites when pulling in or out. Large linemen's gloves to protect hands, but hard on the whites if the "rope" ever came in contact. That black junk did not wash out.
[Reply]  [No Email]
Dr. Walt
02-17-2013 02:21:22
12.2.223.79
First, these are Blocks, there is no Tackle - (rope or cable); also, these are NOT snatch blocks as some have suggested. Snatch blocks have a hinged side-plate to give you direct access to the sheave. Second, if the blocks weigh 45 pounds each, then they are for CABLE not rope. I have single, double, and triple sheave blocks for 1 inch diameter rope and none of them weighs over 10 pounds. Carefully examine your blocks, there should be a weight rating (maximum weight, or safe working load) stamped on either the side-plate or the strap on each of the blocks.
[Reply]  [No Email]
Brian G. NY
02-17-2013 07:13:08
64.22.47.130
 Re: Block and tackle or something else? in reply to Dr. Walt, 02-17-2013 02:21:22
Some may argue that top one in this picture is not a snatch block, but it is.
It is a little inconvenient as you have to remove the pin and pulley to "snatch" it on to a "cable".
Yes, "cable" also known as wire rope. Cable cars are strung from cables, right?
It is my favorite because of its compact size.
[Reply]  [No Email]
MO8N4ME
02-17-2013 07:22:50
72.172.196.40
 Re: Block and tackle or something else? in reply to Brian G. NY, 02-17-2013 07:13:08
Yup!!!
[Reply]  [No Email]
Bret4207
02-17-2013 05:14:39
64.19.90.196
The man is the winner. What's really, really sad is that mechanically inclined people as frequent this forum don't know what they are. Oh, how times have changed. :roll:
[Reply]  [No Email]
Ultradog MN
02-17-2013 00:31:44
174.30.216.68
Everyone is talking about blocks and tackle.
Those are blocks.
There is no tackle (rope or cable)in the picture.
[Reply]  [No Email]
John in la
02-16-2013 21:29:10
184.38.177.171
That is a set of block and takle.
The ring on the side opposite the hook is replaced by the thimble in the bottom picture.
I assume the one at the top of the picture also has 2 pulleys or the thimble would be on that one.
With 2 pulleys each and a thimble on one of they it is set up to be a twofold purchase tackle. This gives a 4 to 1 mechanical advantage.
[Reply]  [No Email]
MO8N4ME
02-16-2013 20:44:07
72.172.196.40
It looks like the center pin is removable from the pulleys of the OP's original picture. If that is the case, both of these pulleys can be utilized as snatch blocks.
[Reply]  [No Email]
MO8N4ME
02-16-2013 20:30:57
72.172.196.40
This is a snatch block!
[Reply]  [No Email]
MarkB_MI
02-17-2013 04:21:58
75.198.116.81
 Re: Block and tackle or something else? in reply to MO8N4ME, 02-16-2013 20:30:57
No, it isn't.
[Reply]  [No Email]
Brian G. NY
02-16-2013 19:12:16
64.22.47.130
Rope block and tackle. can I am assuming the top one in the picture has one pulley?
Not a snatch block.
A snatch block has only one pulley and must have a way of opening so that it can be placed on the cable at any point without having to thread the rope or cable thru it.
I'm guessing that's where it gets its name "snatch" block as it can snatch the cable or rope at any point.
[Reply]  [No Email]
Dalet
02-16-2013 20:00:08
184.94.141.146
 Re: Block and tackle or something else? in reply to Brian G. NY, 02-16-2013 19:12:16
True. I wasn't looking clearly to see that you would have to unbolt it to run the cable through.
[Reply]  [No Email]
OH - 961
02-16-2013 18:36:51
66.19.61.154
They are snatch blocks for steel cable - not fiber rope. They can actually be used as a block and tackle by running a cable from a winch around one of the pulleys on the double block, then around the single block, and secure the bitter end of the cable to the thimble on the double block.
You actually have a mis-matched pair, as both of them should be double pulleys to rig it correctly.
OR
Move the thimble and secure the bitter end of the cable to the single pulley, so you can utilize both sides of the double pulley.
It will be fairly easy to figure out just by experimenting a bit.
Myron
[Reply]  [No Email]
Waltdavies
02-16-2013 19:11:26
70.199.224.85
 Re: Block and tackle or something else? in reply to OH - 961, 02-16-2013 18:36:51
Those are not Snatch blocks. A snatch has the ability o open
at one end to except the rope or cable use to double up you
pulling power
Walt
[Reply]  [No Email]
WaltDavies
02-16-2013 19:17:58
70.199.224.85
 Re: Block and tackle or something else? in reply to Waltdavies, 02-16-2013 19:11:26
This is a snatch block.
Photobucket Pictures, Images and Photos
[Reply]  [No Email]
Brian G. NY
02-16-2013 19:24:38
64.22.47.130
 Re: Block and tackle or something else? in reply to WaltDavies, 02-16-2013 19:17:58
Exactly, Walt! I have a couple of HD ones made for steel cable (wire rope) and I use them regularly in the woods when I cut a tree that leans in the wrong direction. By hooking low on another tree located in the direction I want the tree to fall I can pull the tree over and have me and the tractor out of harm's way.
Hooking low also gives the tractor better traction.
[Reply]  [No Email]
Dalet
02-16-2013 18:10:01
184.94.141.146
I love the diesel Nissan
[Reply]  [No Email]
MO8N4ME
02-16-2013 17:53:42
72.172.196.40
I edited my post above with this link at YouTube with one working.
Snatch Block at work
[Reply]  [No Email]
MO8N4ME
02-16-2013 17:44:20
72.172.196.40
I thinking it's called a snatch block.
Snatch block at work
This post was edited by MO8N4ME at 17:51:05 02/16/13.
[Reply]  [No Email]
Dalet
02-16-2013 17:46:03
184.94.141.146
 Re: Block and tackle or something else? in reply to MO8N4ME, 02-16-2013 17:44:20
Yup a snatch block. Use for winching something heavier than your winch is capable of. It will halve the speed and double the force.
[Reply]  [No Email]
acken fromwisc
02-16-2013 17:31:12
68.114.245.172
I would say you have half of a block and tackle, you need another set of pulleys to make this work.
[Reply]  [No Email]
Centex Farmall
02-16-2013 16:56:51
173.9.203.106
You can also rig that for horizontal pulling which is great for loading dead machinery. I have a set with single pulleys and can rig a single or double line. You can get even more leverage since you have two pulleys.
[Reply]  [No Email]
glen sw wi
02-16-2013 16:30:09
207.190.82.135
If there isn't a pully on the other piece,it can't be a block and tackle. Would have to have at least one pully. Can not tell from the pic..
There would be no need for two pullies on the one if there isn't one on the other.
[Reply]  [No Email]
evilboweivel
02-16-2013 16:06:39
75.185.40.180
block and tackle for a rope
thimble on bottom one for end of rope to wrap aqnd be spliced into an eye
[Reply]  [No Email]
ss55
02-16-2013 16:01:11
173.31.19.80
That looks like a block and tackle to me.
There is a metal loop bent around the right hand bolt on the lower unit. That is where the end of the rope would be fastened. Sorry, but I just can't think of what that is called right now, they are made to prevent wear on the looped end of a rope or cable.
[Reply]  [No Email]
GVSII
02-17-2013 08:35:03
74.71.178.71
 Re: Block and tackle or something else? in reply to ss55, 02-16-2013 16:01:11
A block but no tackle. There would be a pulley(s) in the upper block.
[Reply]  [No Email]
boler76
02-16-2013 17:49:40
184.151.61.85
becket
[Reply]  [No Email]
CharlieNJ
02-16-2013 16:07:35
76.117.68.151
You are correct, and that "metal loop" is called a thimble. That rig would be a triple purchase.
Regards,
Charlie
[Reply]  [No Email]
rustred
02-16-2013 15:54:15
69.58.16.5
maybe you could make yourself a cable lift for a blade in front of the tractor like the old cats had.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
