Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: Wanted: hydraulic front wheel drive for farm tractor
Janicholson
02-04-2013 18:38:05
THe control of the tire surface speed is near impossible with a hydraulic drive. Not that it cant be controlled, but it isnt directly proportioned to ground speed of the rear tires. It could be with a hydrostatic system, and computer and sensor based evaluation of ground speed. but that is going to cost more than a 4X4 tractor.
(because it would need to be developed)
Jim
Bob
02-04-2013 19:17:54
 Re: Wanted: hydraulic front wheel drive for farm tractor in reply to Janicholson, 02-04-2013 18:38:05
Of course, it the wheel motors were fed from a constant pressure closed-center hydraulic system like the Deere units on the 4430"s and 4630"s (etc.) were the front wheels would contribute a constant pull/torque and the gpm hyd. flow/derived speed wouldn"t be an issue.
Janicholson
02-04-2013 20:20:55
 Re: Wanted: hydraulic front wheel drive for farm tractor in reply to Bob, 02-04-2013 19:17:54
Other than when one pushes in the clutch! It seems like a very good way to make heat in a hydraulic system as well as the complexity of a system that will be parasitic nearly all the time. Not my idea of best practice. Jim
Bob
02-04-2013 20:35:23
 Re: Wanted: hydraulic front wheel drive for farm tractor in reply to Janicholson, 02-04-2013 20:20:55
With the Deere "closed center" system, oil heating was NOT a problem. I forget how Deere cut the power to the hydraulic FWA when the clutch was depressed... will have to look at the service manual tomorrow. Bottom line was the it was NOT as powerful as a mech FWD, but ASSISTED and did a reasonable job thereof. Biggest problem was oil leaks/hose failures.
Tx Jim
02-05-2013 03:13:03
 Re: Wanted: hydraulic front wheel drive for farm tractor in reply to Bob, 02-04-2013 20:35:23
The only reason I see why "no heating of hyd oil problem" on a HFWA would be the limited amount of time the HFWA was engaged. The orbit motors on implements such as a JD 700 rake will definitely heat the oil on a closed center system
