| Tractor Talk Discussion Forum |
Topic: Wanted: hydraulic front wheel drive for farm tractor
[Return to Forum]
| Author |
[Modern View]
| MF rules
02-04-2013 18:05:32
166.147.104.156
Looking for a complete front wheel drive axle assembly that would fit an John deere 4430 or international 1066 size tractor. Want to put it on a Massey 1155. Thanks |
[Reply] [No Email] | |
| 4020guy
02-04-2013 22:50:57
68.171.72.108
Re: Wanted: hydraulic front wheel drive for farm tractor in reply to MF rules, 02-04-2013 18:05:32
| The "clutching" was made possible by 3 solenoid valves and micro switches. These also controlled the high torque[hydraulics in parallel] and low torque[hydraulics in series] settings for the axel. The system on the Deere 20,30, and 40 series probably worked better in theory than in actuality even with the 4 cubic inch per revolution close centre pump. Combine hydrostats operate at much higher pressures so had alot more torque. MF rules, I think it would be quite a project but I would be afraid it would have disappointing results. Ever consider an older 4 wheel articulated?....Ron |
| MN Scott
02-04-2013 19:24:28
184.158.27.231
| Here's one in MN. |
| Janicholson
02-04-2013 18:38:05
74.60.94.18
| THe control of the tire surface speed is near impossible with a hydraulic drive. Not that it cant be controlled, but it isnt directly proportioned to ground speed of the rear tires. It could be with a hydrostatic system, and computer and sensor based evaluation of ground speed. but that is going to cost more than a 4X4 tractor. (because it would need to be developed) Jim |
| Bob
02-04-2013 19:17:54
64.255.159.192
Re: Wanted: hydraulic front wheel drive for farm tractor in reply to Janicholson, 02-04-2013 18:38:05
| Of course, it the wheel motors were fed from a constant pressure closed-center hydraulic system like the Deere units on the 4430"s and 4630"s (etc.) were the front wheels would contribute a constant pull/torque and the gpm hyd. flow/derived speed wouldn"t be an issue. |
| Janicholson
02-04-2013 20:20:55
74.60.94.18
Re: Wanted: hydraulic front wheel drive for farm tractor in reply to Bob, 02-04-2013 19:17:54
| Other than when one pushes in the clutch! It seems like a very good way to make heat in a hydraulic system as well as the complexity of a system that will be parasitic nearly all the time. Not my idea of best practice. Jim |
| Bob
02-04-2013 20:35:23
64.255.159.192
Re: Wanted: hydraulic front wheel drive for farm tractor in reply to Janicholson, 02-04-2013 20:20:55
| With the Deere "closed center" system, oil heating was NOT a problem. I forget how Deere cut the power to the hydraulic FWA when the clutch was depressed... will have to look at the service manual tomorrow. Bottom line was the it was NOT as powerful as a mech FWD, but ASSISTED and did a reasonable job thereof. Biggest problem was oil leaks/hose failures. |
| Tx Jim
02-05-2013 03:13:03
67.142.163.24
Re: Wanted: hydraulic front wheel drive for farm tractor in reply to Bob, 02-04-2013 20:35:23
| Quoting Removed, click Modern View to see
The only reason I see why "no heating of hyd oil problem" on a HFWA would be the limited amount of time the HFWA was engaged. The orbit motors on implements such as a JD 700 rake will definitely heat the oil on a closed center system |
| Paul
02-04-2013 18:20:56
66.44.133.112
| | No you don't, not if what I hear about them I's true. ;) Don't know of any, sorry I'm not being helpful here. But, seriously, never heard much good about those setups? They weren't around long.... Paul |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
