TractorLinks.com
Tractor Talk Discussion Forum
Re: home built power steering. HELP
Corona Boy
01-31-2013 19:15:40
Ok. I can wrap my head around that. Tractor does not have factory PS. Tractor does not have extra valve block. Only one to run the rear lift. So I will need a spare valve block and a priority valve to make this work? I should also mention that the rear lift doesn't work asI have it plumbed now. However if I bypass the steering setup the rear lift works fine. I have a loader on this tractor that is powered by a PTO pump and seperate resevoir. Maybe tie into that somehow. Loader tractor without power steering is not working for my old body anymore.
Janicholson
01-31-2013 19:24:35
 Re: home built power steering. HELP in reply to Corona Boy, 01-31-2013 19:15:40
Try using the existing (connected) lever to dead head the system to see if we are on track. Lift (or lower) the hitch toi the limit when trying to steer. If joy, that priority valve is in your future. Many are available for that tractor or 300U with PS. The system is not open centered. it is a demand based pressure system with a pilot valve sensing demand and turning on pressure. Jim
Corona Boy
01-31-2013 19:36:50
 Re: home built power steering. HELP in reply to Janicholson, 01-31-2013 19:24:35
I did try moving the lever to the full up and the full down position. Unfortunately no improvement. And the lift wouldn't function. Thanks for all the info.
Janicholson
02-01-2013 15:59:19
 Re: home built power steering. HELP in reply to Corona Boy, 01-31-2013 19:36:50
As it is now your PS unit is doing two things. it is bleeding off low pressure flow, and it is before the pilot valve thus not allowing system pressure to be controlled. This prevents the hitch from working.
Either purchase a IH power steering priority valve and hoses from a PS equipped 300 or 350U.
or buy a seperate priority valve with flow at or greater than your PTO pump. place that in the output of your PTO pump and steering to the PS unit the output port to the loader. Jim
Corona Boy
01-31-2013 19:36:49
