Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: OT Skat Trak mini excavator
[Return to Forum]
Bradiniowa
01-31-2013 17:32:06
184.63.19.28
I know you guys come with all kinds of experience, so here is the problem: try to help a friend diagnose his new to him 520v Skat Trac. Everything works hydraulically except the left side drive for the track. If you jack it up it turns with no noise such as grinding but has no power and appears to do nothing when sitting on the ground. Any help would be appreciated.
[Reply]   [No Email]
GarrettFields
01-31-2013 18:30:26
98.23.15.29
Re: OT Skat Trak mini excavator in reply to Bradiniowa, 01-31-2013 17:32:06
No power under load, but works fine with no load is usually a symptom of a bypassing motor. Easy to check. Pull the case drain( it will be the smallest of the hoses)have your friend hit the tram pedal and see how much oil comes out. A steady drip to a VERY weak stream(its hard to explain) is acceptable. If it pours your motor is bad(bypassing). If the motor doesn't have a case drain, you will have to check for heat. Tram enough to get the system warm. Compare your suspect motor to the good one. If its hot or quite a bit warmer your bypassing. If neither of these get you any where you may want to check pressures(may have compensator, or relief problems for that circuit) and flow. Remember just because you have pressure doesnt mean you have enough flow. If you dont have any gauges the simplest thing would be to swap motors from side to side. If the problem moves its the motor, if it doesnt your obviously looking at something upstream. Hope this helps.
  [Reply]  [No Email]
old
01-31-2013 17:55:23
209.86.226.18
I know just enough about that type of system to get me in trouble LOL. Could be as simple as a bad chain in the drive system or a bad hyd motor or even a simple bad hose to or from the motor. I have the fun of fixing a friends articulating Skat track loader so I know enough to get in trouble but fun to play with from time to time. Years ago I built a post driver that hooks up to his. Did a 3 point post driver hyd type and made a mount so it could be hooked up to it and boy does it work well
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
