Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: kubota engine satrting problems
KMo
01-19-2013 11:00:39
This may not directly apply, but maybe you could use this information and a wiring diagram to find the answer.
Gas vehicle ignition systems used an ignition resistor or a resistive wire to apply 12 volts to the coil during start up and drop to 6 volts during run. They would simply bypass the resistor while cranking and place the resistor in the circuit when the starter was released.
A bad resistor or resistive wire would cause the problem you mention.
If you have a 12/6 volt fuel shutoff solenoid, maybe a similar arrangement is used.
