TractorLinks.com
Tractor Talk Discussion Forum
Re: kubota engine satrting problems
guyman
01-19-2013 10:23:23
The engine is in an asphalt roller. Fuses are good. Fuel pump runs when switch is turned to on. Connections seem to be good.
KMo
01-19-2013 11:00:39
 Re: kubota engine satrting problems in reply to guyman, 01-19-2013 10:23:23
This may not directly apply, but maybe you could use this information and a wiring diagram to find the answer.
Gas vehicle ignition systems used an ignition resistor or a resistive wire to apply 12 volts to the coil during start up and drop to 6 volts during run. They would simply bypass the resistor while cranking and place the resistor in the circuit when the starter was released.
A bad resistor or resistive wire would cause the problem you mention.
If you have a 12/6 volt fuel shutoff solenoid, maybe a similar arrangement is used.
