Tractors sweating!??? Help
My garage is well insulated we went from 12-20 degrees last week too 60 degrees today.. When I walked in the shop all my tractors I"m working on are soaked from sweating... How do I stop this?
I think you have to the shop warmer so the metal don"t get so cold.....I have this issue in the spring sometimes
jim, you need to get some air flowing through the building, open the windows a little, vented soffits. if heated a dehumidifier would help. chuck
One of two things, find a way to remove the moisture from that southern air before it gets to you, or keep your tractors warmer than the warm air mass that is coming. Don't open windows until you either heat the tractors or the humidity goes down or you will just get more sweating.
Mine sweat in the unheated barn too. Nothing I can do about it.
As a reminder, if they sweat on the outside, they sweat on the inside.
Expect to find some water/moisture in the oils.
No pumping more warm wet air in to your cold tractor will just
make it sweat worse. Any time its colder than the dew point of the
air it will sweat.
Easy to stop it you just make sure it has true control of heat and cold as in you keep it at say 70 degrees year round. Condensation is a fact to life unless you do things like heat and cool a building so as to keep it from being able to happen
This means a good storm is headed your way! Believe me!!
Other signs to watch for too is;
Fluid filled tires sweating
Garage door opener works from a farther distance
Cars on a gravel road can be heard a mile away.
A person's voice will echo between the buildings.
These are just a few that I have noticed and can remember.
Plug in the coolant and oil heaters if equipped. The warmth will keep some of the critical areas of the machine from collecting condensation.
It's how dehumidifiers work. Warm moist air meets cold and moistures condenses. My garage floor looks like it rained on it every spring till it equalizes temps.
I have four tractors lined up in a tobacco barn for oil change and general maint. they all have been dripping twice today with the doors open. I have a lot of moisture in the transmissions and rears on my tractors here in central KY.
Mine do too. They're in an unheated pole barn. In spite of occassional sweating they don''t seem to accumulate much water in the engine or transmission oil. I just crack the drain plugs in the spring and rarely get more than a tablespoon of water out of anything.
