Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: propane/tank questions
[Return to Forum]
R Wyler
01-12-2013 10:08:51
70.137.30.18
I do understand propane or the basics anyhow and have had a 930 Case LP for several years. Anyhow I tried to start a Moline G705 yesterday for the first time. I had to replace the vapor valve and the 80% valve as well as the liquid filler valve. I put about 5% in the tank and the tractor was not wanting to start and of course with the vapor valve on only. It tried but mostly smoke. It was around 60 degrees. I opened the 80% valve and liquid come out. I got to thinking maybe I was only getting cold liquid to the carb? This might be a stupid question but could the cooler temps be my problem?
[Reply]   [No Email]
Dalet
01-12-2013 21:06:57
72.21.249.236
Re: propane/tank questions in reply to John B., 01-12-2013 10:08:51
Thanks Owen! I have forgot many things over the years and this is one of them!
  [Reply]  [No Email]
ILL John
01-12-2013 19:51:32
99.115.64.84
Re: propane/tank questions in reply to R Wyler, 01-12-2013 10:08:51
I've got a M670, had the same problem, only I've never seen a propane tractor smoke, until I installed a "high preformance" coil, now it starts on the 1st 1/4 turn even at 0 degrees.
  [Reply]  [No Email]
R Wyler
01-13-2013 06:53:35
70.137.26.250
Re: propane/tank questions in reply to ILL John, 01-12-2013 19:51:32
I am interested in a high performance coil that sounds good. As far as the smoke I know it has to the the oil on the pistons. Glad to see it I know I had plenty in there to keep from starting it dry. Cold here today for Okla anyhow low 30s. I sure am wanting to hear it run and know that all is good with it. It has been a long enough wait..
  [Reply]  [No Email]
Dalet
01-12-2013 18:30:54
72.21.249.236
I am not sure how cold it is where you are, but if I remember right, at -20 there is zero pressure from propane. You can carry it around in a pail as liquid. What is the temp?
Okay, I see that you were trying to run it at 60 deg. That won't be the issue then, sorry.
I have a propane pickup and a 400 Farmall LP and if I want to run them in the cold, I plug them in.
This post was edited by Dalet at 18:31:54 01/12/13.
  [Reply]  [No Email]
R Wyler
01-13-2013 06:56:33
70.137.26.250
Re: propane/tank questions in reply to Dalet, 01-12-2013 18:30:54
Yes it was warm enough but the liquid comeing out of the 80% valve has me thinking something is not quite right. I only put about 5% in the tank. I am going to make sure that I am getting only vapor out of it with the only vapor valve on.
  [Reply]  [No Email]
Owen Aaland
01-12-2013 21:02:37
216.47.35.85
The boiling point of propane is about -44°F.
  [Reply]  [No Email]
Owen Aaland
01-12-2013 17:22:33
216.47.35.85
The LP regulator requires a slight vacuum (either 1/2" or 1 1/2" W. C. depending on model) to open to allow fuel to flow to the mixer. Without oil in the air cleaner there might not be enough vacuum at cranking to open the regulator.
A gasoline carburetor does not have this characteristic so it should work without the air cleaner attached.
This post was edited by Owen Aaland at 17:22:51 01/12/13.
  [Reply]  [No Email]
R Wyler
01-12-2013 17:47:25
70.137.30.18
Re: propane/tank questions in reply to Owen Aaland, 01-12-2013 17:22:33
Okay that is good to know. I will get oil in the cleaner and check the distrib timing ect again.
  [Reply]  [No Email]
MSD
01-12-2013 12:31:19
67.4.60.56
How is the air cleaner on it? Won't start with the oil bath removed or no oil in it.
  [Reply]  [No Email]
tools
01-13-2013 08:58:03
206.221.154.149
Re: propane/tank questions in reply to MSD, 01-12-2013 12:31:19
Never heard of that before. I have one I use as a puller, and I run it with a K&N style filter clamped on the carb. It starts right up, even without the filter.
  [Reply]  [No Email]
R Wyler
01-12-2013 14:18:31
70.137.30.18
It is all intact and clear with all new hoses ect but it does not have oil. I feel foolish but I had no idea it would keep it from running. This is the first time I heard about this. Is it only on an lp carb?
  [Reply]  [No Email]
MSD
01-12-2013 18:30:30
67.4.60.56
Re: propane/tank questions in reply to R Wyler, 01-12-2013 14:18:31
Took me a while to figure it out on my first one too.
  [Reply]  [No Email]
casecollectorsc
01-12-2013 11:21:46
75.102.169.45
I start my 930 Case when it is -20 below to blow snow ect. Start on vapor and after warm a little switch to liquid, so temp. where you are shouldn't be an issue.
  [Reply]  [No Email]
R Wyler
01-12-2013 11:29:48
70.137.30.18
Re: propane/tank questions in reply to casecollectorsc, 01-12-2013 11:21:46
Yes I did not expect a problem. If the weather does not get worse and I can get to the farm today I am going to check this out and see if I am getting vapor only out of it. I am thinking I was getting cold liquid only which could cause this problem. The tank was empty and no pressure on it. I did not even have to vent it to put fuel in. I am running out of ideas.
This post was edited by R Wyler at 11:31:39 01/12/13.
  [Reply]  [No Email]
R Wyler
01-12-2013 10:14:04
70.137.30.18
Thinking about it more though when I turned it on and tightened the fitting going to the filter I did not see any liquid or any signs of sweating on the carb or lines ect. I am thinking I have a fuel system issue. Also the regulator is brand new. I will take the line going to the reg loose and see if liquid comes out with vapor only on.
This post was edited by R Wyler at 10:19:30 01/12/13.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
