TractorLinks.com
Tractor Talk Discussion Forum
Re: Tire pressure
Walt Davies
01-05-2013 18:07:27
Check your air pressure about the same temp each day adjust up or down a few lbs to make up for the temp difference. The pressure is a estimated amount it doesn't hurt to be a little off. On your car the smaller the tire the closer you should be to the amount on the door or under the hood. On big trucks with large tires they can be anything from around 85 to 110 lbs depending on how much weight you are carring. On my big trailer it's says 110 for 3100 lbs per tire. On my dump truck it is around 85 to 95 depending on the load. But it's not critical it's a estimated pressure.
Walt
