Yesterday's Tractor Co.
Shop Now View Cart
Tractor Talk Discussion Forum
Re: drilling and tapping cast
01-05-2013 09:38:32
Nope nothing special. Be sure you used a pipe tap unless you are planning on using something with a gasket.
Super Steve
01-05-2013 09:42:06
 Re: drilling and tapping cast in reply to oldtanker, 01-05-2013 09:38:32
I was just planning on using a bolt with a rubber washer.
01-05-2013 09:45:16
 Re: drilling and tapping cast in reply to Super Steve, 01-05-2013 09:42:06
That will work too. I prefer pipe plugs of the kind thing but the other way works too as long as the gasket seals.
bill mart
01-05-2013 10:14:28
 Re: drilling and tapping cast in reply to oldtanker, 01-05-2013 09:45:16
is there ever a chance of the pipe plug splitting the casting if you screw it in too far?
01-05-2013 10:38:50
 Re: drilling and tapping cast in reply to bill mart, 01-05-2013 10:14:28
Nothing to worry about unless you decide to really over tighten the threads. Generally the only castings that could be expected to break are those made from Pot metal, or thin aluminum. Use a one wrap strip of teflon tape and all is well. (consider putting a metal or ABS plastic shield over the shaft where the water leaks in. Jim
Jim in Ma.
01-05-2013 10:33:55
Yes - Pipe thread is tapered. Just do not over tighten the plug.
