| Tractor Talk Discussion Forum |
Topic: IH 684 lift arms stuck up... hydraulics constant pumping??
[Return to Forum]
| Author |
[Modern View]
| bluedog1
01-01-2013 14:22:17
88.87.186.170
hi got an ih 684 wit da lift arms stuck up and da hydraulics constant pumping! tried the usual things like checkin da valves etc but problem still der any ideas??? |
| jimb2
01-01-2013 15:45:13
174.114.182.155
Re: IH 684 lift arms stuck up... hydraulics constant pumping?? in reply to bluedog1, 01-01-2013 14:22:17
| Hi Bluedog, Two things to check from Bernard le mencano for 3 pt will not go down:There is a cover in the right side, in front of the rock-shaft. Remove and check if the spool valve moves with the position lever. Make sure the draft lever is down. It has a long spring, with a rod, maybe the spring is unhooked. Bernard le mécano Québec Canada Hi, maybe the unload valve is stuck. Check with engine running, raise the hitch and at the same time pull the remote hydraulic lever. If the hitch raises, you have dirt in the unload valve. This valve is under the seat and you remove the large plug for access. One trick, loosen the large plug, unload valve, 2 turns and start the engine, the hitch should raise if the valve is stuck. It has a small hole in the valve and just blow the dirt out with air. Replace with new O rings. Bernard le mécano Québec Canada Hope this helps JimB
| Janicholson
01-01-2013 15:18:01
74.60.94.18
| The draft control sensor is probably jumped out of place. See the archives for how to do it (IIRC) it is through the top link mounting plate access hole. It involves getting a follower back on the correct side of a long cam like arm. Jim |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
