Yesterday's Tractor Co.
Shop Now View Cart
Tractor Talk Discussion Forum
Re: Diesel fuel tank repair
Super Steve
01-01-2013 08:40:59
So I've got the JB weld all cleaned off. Managed to chip most of it off then sanded the rest down to clean metal. I'm thinking of trying the solder then putting the Seal-All stuff over top of the solder. Think that will work?
Ultradog MN
01-01-2013 09:39:36
 Re: Diesel fuel tank repair in reply to Super Steve, 01-01-2013 08:40:59
If you solder it right you don't need no pucky stuff.
If you want to read a little story from when I soldered one of my tanks a year or two ago click below.
01-01-2013 09:54:42
 Re: Diesel fuel tank repair in reply to Ultradog MN, 01-01-2013 09:39:36
I had to solder the drain bung back onto the bottom of a tank a couple years ago. As I was applying the solder, some dripped down into the tank and started the little residue of fuel burning. I guess it went out after awhile cause the tank wasn't hot when I put it back on the tractor.
01-01-2013 09:05:58
If you dont remove the tank you're wasting your time...There will still be fuel in the seam.An electric gun wont develop enough heat or 'burn' out the 'moisture'.I would not want to use a flame on an unwashed tank
01-01-2013 10:35:35
 Re: Diesel fuel tank repair in reply to DeltaRed, 01-01-2013 09:05:58
On diesel and oil tanks that need mending, use the exhaust from a vacuum cleaner and put the hose in the tank. This will keep the fumes and smoke blown out so they can't reach an ignition temp or mixture. I used leaf blower once on a 500 gallon tank.
On gasoline tanks use the exhaust NOT suction to dry out the tank, then keep blowing when soldering or welding or brazing.
