Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: Re: wainscoating in bedroom question
[Show Entire Topic]  [Return to Forum]
Justin SE IOWA
12-27-2012 17:29:06
166.182.80.100
Base board goes on top of carpet right? Also how do I fasten the wains coating to the sheet rock? Do I have to put a furring strip at the top and bottom? Im afraid that will make it stick out from the wall to far. Is there a better way?
[Reply]   [No Email]
State of Jefferson
12-27-2012 17:48:14
75.210.244.92
Re: wainscoating in bedroom question in reply to Justin SE IOWA, 12-27-2012 17:29:06
You don't HAVE to pull the carpet. The wainscoting doesn't HAVE to go clear to the floor. Infact if you are not wanting to replace the carpet right now, i'd leave it up enough to pull the old carpet. The baseboard should go pretty tight to teh carpet.
When I install baseboard in a house and the painter, carpet layer and myself are all on tha same page, I isntall baseboard BEFORE carpet, about 1/2" above the subfloor. Paint it in place, then the carpet layer can tuck the carpet right under. Saves alot of hassle masking/ cutting in paint against carpet.
The IDEAL way to install wainscotting is to cut the sheetrock back, add nailers(and possible more insulation on exterior walls) then the wainscoting, then chair rail above and baseboard below, as a way to aleiviate the sticking out into the room problem.
Just my humble advice. Worth every cent you paid for it!
Ben
  [Reply]  [No Email]
Frank (N.Mi.)
12-27-2012 17:38:06
69.35.200.185
Well if you are using vertical boards for your wainscot and the existing wall isn't blocked or sheated under the sheetrock your only options are to find a good cons't adhesive and glue the boards or remove the sheetrock where the wainscot is going to be and sheet the framing with plywood to give the nails or screws something to fasten into. We had to do this on a place this past summer.
  [Reply]  [No Email]
Hoenes
12-27-2012 18:03:29
99.195.155.70
Re: wainscoating in bedroom question in reply to Frank (N.Mi.), 12-27-2012 17:38:06
Pull carpet back. One way to get the "old" look, is to start out with a 1 inch, or 5/4 base board (if you are using 3/4 wainscoat) say a 1x4 or 1x6 and set your 3/4 boards on top of the base. Set your base on 3/8 blocks, (remove after install) and the carpet layer will tuck underneath base. Glue is fine, but if you have access to a trim nailer, you can toe-nail the edge of the tongue on a 45 to hold them in place till the glue dries.
  [Reply]  [No Email]
Justin SE IOWA
12-27-2012 17:40:55
166.182.80.100
I had thought about this also. I really dont want want to use adhesive.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
