Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: asphalt shingles or tin on old farm house
Sid
12-27-2012 08:50:22
How many of you guys ever fight a house fire that had metal roofing?
MarkB_MI
12-27-2012 11:46:24
 Re: asphalt shingles or tin on old farm house in reply to Sid, 12-27-2012 08:50:22
I haven't tried to put out a burning metal-roofed building. But as a boy I watched an old wooden grain elevator burn down. It had been sheathed in corrugated steel, and after a couple of sheets fell down, the volunteer firefighters got the heck out of there.
showcrop
12-27-2012 09:27:15
I have a few times. Are you going to tell us how those metal roofs hold the heat in? That's OK, most fires give up too easy anyway.
Sid
12-27-2012 13:30:08
 Re: asphalt shingles or tin on old farm house in reply to showcrop, 12-27-2012 09:27:15
"Are you going to tell us how those metal roofs hold the heat in?"
No I am not going to tell you anything. Just asking a question. I wonder if it would hold the heat in and make it harder to fight a fire or not.
showcrop
12-27-2012 14:37:51
 Re: asphalt shingles or tin on old farm house in reply to Sid, 12-27-2012 13:30:08
No, it doesn't really make any difference because you can't go into a building unless it is safe, and it can only be safe for as long as most of the structure is still intact, as long as it is pretty much intact it is going to be very hot as in 1,000 degrees or better, regardless of what type of roof it has. Once you vent it to make it more comfortable to work in, you have to move fast and get to the seat of the fire with the water, because once it gets air it is going to burn up fast and become unsafe. Then you have to back out and spray water from the outside, which is not much fun especially in the winter.
Copyright © 1997-2015 Yesterday's Tractor Co.
