TractorLinks.com
Tractor Talk Discussion Forum
Re: OT/Ford
BushogPapa
12-26-2012 20:25:34
10 1/2 Volts tells it ALL....
That Battery has a bad cell....and they will not start with 10 1/2 Volts..
The "Dimming" of your lights is when the battery drops to 10.5 V and gets Bright when the battery snaps back to 12 V..(all 6 cells working)..
I would try with a New Battery, before I did anything else..! Ron..
Janicholson
12-26-2012 20:34:05
 Re: OT/Ford in reply to BushogPapa, 12-26-2012 20:25:34
A bad battery can have the effect, but the draw on the system, after charging, will take the battery down over night. With respect, Jim
BushogPapa
12-26-2012 20:39:00
 Re: OT/Ford in reply to Janicholson, 12-26-2012 20:34:05
He said the Battery showed only 10.5V after he charged it... I would change the Battery..
Ron..
Janicholson
12-26-2012 21:06:26
 Re: OT/Ford in reply to BushogPapa, 12-26-2012 20:39:00
Woth respect. the way I read the post he charged it normally with the terminal off. It then (and still has, I think) a charge. Jim
Retired Farmer
12-26-2012 22:40:44
 Re: OT/Ford in reply to Janicholson, 12-26-2012 21:06:26
True. When I charged it with the cables both hooked up it still read around ten volts. I disconnected the positive and it charged to 14.7. Haven't checked it today to see if it is still up.
uncletom
12-27-2012 02:17:30
 Re: OT/Ford in reply to Retired Farmer, 12-26-2012 22:40:44
Had a 79 ford that run the battery down. Put the amp meter in between the positive post and battery. It had a 2 amp draw on it. I started unplugging everything one at a time. Long story short it was the voltage regulator that was drawing the 2 amps. On that truck it was external.
