TractorLinks.com
Tractor Talk Discussion Forum
Re: OT/Ford
Dalet
12-26-2012 17:33:31
1. You allow the Coop mechanics to mess with your truck.
2. You have a lot of work trying to figure out what those monkeys did.
I only allow the Coop to put tires on my vehicles. I watch them do it. They aren't paid well.
Retired Farmer
12-26-2012 17:43:35
 Re: OT/Ford in reply to Dalet, 12-26-2012 17:33:31
Live and learn. They have two good people there and they evidentally didn't work on it. They have hired several new guys since their business is increasing and I think they just pulled them off the street and had them work on it. Have always had very good luck with them till now.
BushogPapa
12-26-2012 19:16:43
 Re: OT/Ford in reply to Retired Farmer, 12-26-2012 17:43:35
My bet is that there IS a Diode that is bad in the Regulator..I don't care what those guys said...(since you find a 5v drain at the battery)..
Intermittent Open-Cirtcuit in the battery is common (New or Old).. Test that battery, when it is "Dead" and see if it really is...
Too often, 1/2 hr later, that "Dead" battery will start the truck right up..if it is an intermittent open..
rusted nuts
12-26-2012 20:34:10
 Re: OT/Ford in reply to BushogPapa, 12-26-2012 19:16:43
Think yo hit the nail on the head.
Retired Farmer
12-26-2012 19:51:58
COOP did say that the battery showed a little overcharge, 15v instead of 14.7. I went to start it yesterday about noon and when I hit the switch the starter tried to turn over slowly and then quit. I could hear the solenoid click. I got the volt meter and put on the battery and it showed about ten and a half volts. I put the charger on it for a couple of hours and checked it when I got back and it still showed about ten and a half volts. I unhooked the positive cable and put the charger on it again. That is when I discovered the five volt draw with everything turned off. Checked it again and it was up to where it was supposed to be. Haven't tried it again. Left the cable undone. Too cold out to work.
Janicholson
12-26-2012 20:11:12
 Re: OT/Ford in reply to Retired Farmer, 12-26-2012 19:51:58
The draw is dramatic and will draw down the battery over night. The dimming of the lights while operating is a key. A short circuit is possible, but it is more likely an issue with the alternator.
Both problems can be caused from a bad bridge diode. in the alt. Loosen but do not remove the nut on the back of the alternator where the large wire attaches. Put your meter between the removed terminal on the battery, as before. Now remove the alt wire. If the draw goes to millivolts, That is the issue. If no change, then removing fuses one at a time is the next step. Set the meter so you can see it from the fuse box. Jim
BushogPapa
12-26-2012 20:25:34
 Re: OT/Ford in reply to Janicholson, 12-26-2012 20:11:12
10 1/2 Volts tells it ALL....
That Battery has a bad cell....and they will not start with 10 1/2 Volts..
The "Dimming" of your lights is when the battery drops to 10.5 V and gets Bright when the battery snaps back to 12 V..(all 6 cells working)..
I would try with a New Battery, before I did anything else..! Ron..
Janicholson
12-26-2012 20:34:05
 Re: OT/Ford in reply to BushogPapa, 12-26-2012 20:25:34
A bad battery can have the effect, but the draw on the system, after charging, will take the battery down over night. With respect, Jim
BushogPapa
12-26-2012 20:39:00
 Re: OT/Ford in reply to Janicholson, 12-26-2012 20:34:05
He said the Battery showed only 10.5V after he charged it... I would change the Battery..
Ron..
Janicholson
12-26-2012 21:06:26
 Re: OT/Ford in reply to BushogPapa, 12-26-2012 20:39:00
Woth respect. the way I read the post he charged it normally with the terminal off. It then (and still has, I think) a charge. Jim
Retired Farmer
12-26-2012 22:40:44
 Re: OT/Ford in reply to Janicholson, 12-26-2012 21:06:26
True. When I charged it with the cables both hooked up it still read around ten volts. I disconnected the positive and it charged to 14.7. Haven't checked it today to see if it is still up.
uncletom
12-27-2012 02:17:30
 Re: OT/Ford in reply to Retired Farmer, 12-26-2012 22:40:44
Had a 79 ford that run the battery down. Put the amp meter in between the positive post and battery. It had a 2 amp draw on it. I started unplugging everything one at a time. Long story short it was the voltage regulator that was drawing the 2 amps. On that truck it was external.
