330 Standard
I have 2 farmall H's from 2 seperate sources. I have adjusted clutches etc and all seem to be okay. They work just fine in the lower gears pulling a trailer loaded on relatively flat ground but do good to barely pull themselves up a very very slight hill on the road in the 2 higher gears. I'd like to use one of these to pull a hay ride trailer but they won't even pull themselves much less a trailer with people. Does anybody have an idea of what could be wrong or what i need to try or do. They will not pull like my JD's do except in the lower slow gears and those are way too slow for the hay ride shuttle we use at a local festival.
