1 bottom pull type plow
b.jones
A friend of mine has decided to plow his 40 acres of bottom ground. It has a thick layer of sand under the top soil from a flood many years ago. I rode several rounds with him today. A one bottom pull type plow. He is pulling it behind a 9300 John Deere with duals all around and about 5000 of added weight. The Deere was having traction problems so he has a 7930 on front pulling the 9300. I think all total the 2 tractors should weigh around 50000. We measured the furrow today and we were going around 36 inches deep. I think the plow weighs around 5000 lbs. It was doing a very nice job of plowing but we were only doing around 1 acre per hour. It is not going to be a cheap job. Going around 4 mph. He hopes to bring up some good dirt from way down under. The biggest one bottom plow I had ever seen. The 1 bottom by itself is about 4 feet tall.
One like this? Company a few miles from my house has made these for as long as I remember, you can still order a new one today.
Isn't that the basic idea for plows like that? To reclaim land under situations such as that, or at least to mix the good soil with the sand so it will be useful. They are also used for drainage ditches, etc. (So I've been told).
Thank you for posting the picture. Yes, it looks very similar to that one. His would not raise up high like that. We were still sliding the plow on the ground even when it was up. I'll bet its the same company.
Way back when there used to be a "bog plow" here on my farm. I'm told it was a single bottom plow of about 24-26" that was pulled with a bulldozer out in the bog meadows. It was also used on the brush lands. I sure wish I still had it even if it was just for the oddball value. It must have gone for scrap just before I bought the place.
Deep plowing was a common practice in the Imperial Valley of California in the Early 60's I've a slide stored away of Two D 8's pulling a single bottom, plow was 4 ft going 42" depth or better.
I have a JD single bottom Trailing trip plow with a 24" bottom that will easily turn 18" sure use up a 100 hp. It was mostly pulled behind a HD 7. to plow out Gambles Oak roots in newly cleared land
