Question on Hydraulic Valve Hookup.
KCTractors
Location
Central Wi
Just installed a front pump, tank and valve bank on a tractor for a customer,but I do not have the cylinders for the loader. Can I just run a hose from the lift side on the valve to the down side, just in case somebody would pull the valve lever. I don't want to spend money on hoses he won't use?
i was going to give the same answer , cap the ends and it would run over relief if valve accuated.
