Yesterday's Tractor Co.
Shop Now View Cart
Tractor Talk Discussion Forum
Re: IH 1566 Hyd Update
Case Nutty 1660
11-17-2012 06:45:53
Tom just what to say that tractor has two pumps the MCV and a hitch pump that controls 3pt remotes, I belive the pto has its on mounted pump also. those types of problems can drive you crazy, I do have a IH service manual and can scan a specfic item for you if it will help cnt
Tom Barto
11-17-2012 06:56:43
 Re: IH 1566 Hyd Update in reply to Case Nutty 1660, 11-17-2012 06:45:53
Thanks a bunch - I have guage on hopefully I will have that soon...for some measured pressures.
I believe my problem is with the steering system. I used the tractor last spring and the steering gave me some trouble...once on the road returning from the farm I was working on, and then twice hauling two different gigantic stumps (one so large it ripped a logging chain in tension).
They were very fast losses - came back quick.
When it re-presented this fall - I was able to warm the fluid by driving up and down the driveway 5 or 6 times and pressure finally came back...
Then that didn't even work.
It looks like the MCV draws off the reservoir of the tractor...If you had anything that would be worthwhile - it would be a hydraulic diagram for the tractor showing where test ports might be and maybe could understand the hydraulic systems interaction, then work my way thru the system...Once I get the guage and fittings.
