TractorLinks.com
Tractor Talk Discussion Forum
Re: Load bearing wall weight
Stephen Newell
11-16-2012 04:17:51
A steel supplier won't give you advice on the size of an I beam you need. I think the cost of hiring an engineer to look at it would be better spent in steel. A I-beam is realitively cheap. If you have the means of handling it a 10" or 12" I-beam should handle anything. I put a 10-26 I-beam 20' in a house to hold up a second story. I had a engineer give the recomendation on that one. I also built a bridge on my property which span 24' with 2 12" I-beams which I've been driving vehicles over for years. The beams were less than $200.00 each. As far as handling it a 10"-26 I-beam weights 26 pounds per lin ft.
gene bender
11-16-2012 04:47:01
 Re: Load bearing wall weight in reply to Stephen Newell, 11-16-2012 04:17:51
I must have a better steel dealer than you have.
Billy NY
11-16-2012 04:56:01
 Re: Load bearing wall weight in reply to gene bender, 11-16-2012 04:47:01
Or he has very good error and omission insurance.
