Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: EMP resistant tractors ?
[Return to Forum]
jCarroll
11-15-2012 03:15:21
75.22.113.218
EMP - Electro Magnetic Pulse - electromagnetic pulse
Having nothing more to worry about, I'm wondering when tractors adopted components which would fail if subjected to an EMP. Or stated differently, how old would a tractor need to be to be "immune" from EMP in the midwest?
[Reply]   [No Email]
buickanddeere
11-15-2012 12:45:47
184.151.61.92
 Re: EMP resistant tractors ? in reply to jCarroll, 11-15-2012 03:15:21
Diesel with mechanical injection AND a generator instead of a alternator. A points equipped gasser would start back up after the pulse passed.
A vacuum tube radio would be ok.
[Reply]  [No Email]
wisbaker
11-15-2012 12:12:05
207.118.181.192
IC's can be hardened to prevent damage from EMP. Today's combat aircraft have a lot of solid state devices yet they consider the Aircraft to be nuclear hardened. The trick is to collect the emr's (electro-magnetic radiation) and dissipate it. Remember dealing with the debates on repairs on our Aircraft when I was in the Air Force, we had to be real careful about any wiring harness that was shielded to insure we didn't mess up the shield and we maintained all grounding and bonding of components. When I moved into an EOD slot some of the fuzes and other components were EMR sensitive so some of the render-safes involved a technique called WIF (wrap in Foil) or bed it in a sand filled steel ammo can. Much equipment is tested for EMR interference, a lot of cars and equipment used to go to upper Michigan and be tested on the ELF line up there to see if could get scrambled by the EMRs. They also test the vehicles to insure they don't emit EMRs that could mess themselves or other vehicles up. I'm waiting for someone to try using the EMR excuse for runaway vehicles.
[Reply]  [No Email]
David G
11-15-2012 11:42:42
204.29.138.33
I would only feel secure having a diesel with mechanical injection, running and manual fuel shutoff.
[Reply]  [No Email]
old
11-15-2012 07:45:07
209.86.226.40
Any of them that have the points condenser and coil and battery will be just fine in an EMP since those are machaical (sp) type systems. It is the electronic ignition systems with chips in them that will be fried
[Reply]  [No Email]
Chip812
11-15-2012 06:33:28
216.226.180.2
As far as I know, diesel tractors should run without any electrical components.
[Reply]  [No Email]
Fawteen
11-15-2012 06:45:54
72.65.109.142
 Re: EMP resistant tractors ? in reply to Chip812, 11-15-2012 06:33:28
Older ones, yes. I don't even need a key, a screwdriver will start it in a pinch.
Newer ones, with all the EPA-mandated electronic controls? Dunno for sure, but I doubt it.
Also, last I knew, the circuit traces on a printed circuit board were enough "antenna" for an EMP to toast the board.
[Reply]  [No Email]
LJD
11-15-2012 05:01:27
75.194.136.235
I don't know if any of them would fail. The biggest EMP problem, in theory, is for devices with integrated circuits that are hooked to things that act like antennas and absorb the pulse. That can be the electric grid, actual antennas, etc.
Little recent "real world" testing has been done since above ground nuclear testing has been banned since the early 60s.
Regardless - I assume any tractor that lacks ICs to run is absolutely safe. Gas engine with ignition points and coil, diesel with mechanical injection, etc. The only parts of some of those tractors that may have an IC or two are the charging systems IF they have alternators with ICs in the regulators.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
