Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tractor Talk Discussion Forum
Topic: Battery Question
[Return to Forum]
Ron Corkum
11-14-2012 05:37:32
71.7.157.140
If a fully charged, disconnected battery is left exposed out in the rain ,will it discharge?
Seems to me water is a conductor of electricity.
It rained here last night and I am looking out at my exposed battery sitting there in the rain,this morning!Does anyone have experience with this type of battery exposure?
[Reply]   [No Email]
barnE
11-14-2012 16:33:48
67.172.83.183
 Re: Battery Question in reply to Ron Corkum, 11-14-2012 05:37:32
When I was apprentice in 1969, I remember checking glass of water and resistance was around 7 thousand ohms with a simpson meter. This was done after an electrical box was found to be filled with water and rust and impurities. All were surprised including engineers. Dave (Probes were one inch apart in water.)
[Reply]  [No Email]
donjr
11-14-2012 09:00:54
72.71.187.124
It won't normally hurt it. Pure water conducts very little voltage, if any. Rain water is not pure, and dirt and trash on the battery between the posts will cause a minor discharge but it is very small, and normally does not affect normal use. A larger buildup will cause it to discharge this way more rapidly, but even then, it may not be noticed in normal use. Most water, due to impurities, is slightly conductive. Distilled water is about as pure as you can get. Rain water only has dirt and particles of dust and other contaminates it may have picked up in the atmoshere and is also very close to being pure.
[Reply]  [No Email]
gene bender
11-14-2012 10:31:12
207.177.56.85
 Re: Battery Question in reply to donjr, 11-14-2012 09:00:54
So if i am standing in water i will not get zapped.
[Reply]  [No Email]
buickanddeere
11-14-2012 14:03:25
184.151.61.246
 Re: Battery Question in reply to gene bender, 11-14-2012 10:31:12
Re-read all the posts. The answer is there more than once.
[Reply]  [No Email]
old
11-14-2012 07:41:02
209.86.226.40
Not likely to cause any problems. Just to prove it you can take a jar f distilled water and put 2 wires in it and hook those one side to a light bulb and the other to a post oif the battery and the other side if that bulb to the battery and the light will NOT light up. Water does not conduct electricity. Ya rain water does have impurities that might conduct but you would have to have a very dirty rain to cause much if any problem
[Reply]  [No Email]
buickanddeere
11-14-2012 07:16:32
184.151.63.162
The 900MW , 1.2 million HP generators run cooling water through the hollow stator bars . Stator bars operate at 27,000 volts.
[Reply]  [No Email]
pete black
11-14-2012 07:34:03
166.147.120.23
 Re: Battery Question in reply to buickanddeere, 11-14-2012 07:16:32
however: does the cooling water in the hollow stator bars actually come in contact with the stator coils?
[Reply]  [No Email]
buickanddeere
11-14-2012 10:08:44
184.151.63.162
 Re: Battery Question in reply to pete black, 11-14-2012 07:34:03
Cooling water runs right through the middle of the hollow 27,000V energized stator bars. Stator bar is approx the dia of a beer can and 30 feet long.
[Reply]  [No Email]
pete black
11-14-2012 07:34:03
166.147.120.23
[Reply]  [No Email]
buickanddeere
11-14-2012 14:05:50
184.151.61.246
Yes the cooling water contacts, touches and is not insulated from the 27,000 volts.
[Reply]  [No Email]
David G
11-14-2012 06:18:47
204.29.138.33
Wash the top off, then should be fine. The wet contaminates conduct, not the water.
[Reply]  [No Email]
Dick2
11-14-2012 06:15:39
174.19.205.113
I was told that the way to harm a battery more than any other way, was to install it and not anchor it down firmly. I knew lots of farmers that just put a battery in a case or frame and let it bounce around because it was not bolted down.
Rain shouldn't hurt the battery at all. Not securing it in place will harm a battery.
[Reply]  [No Email]
ohiojim
11-14-2012 06:02:55
50.126.54.104
pure water will not conduct electricity,...only the minerals in it will,
[Reply]  [No Email]
Russ from MN
11-14-2012 06:02:46
68.235.89.15
Clean water does not conduct electricity, however the top of the battery probably has some dirt on it. A good hard rain would probably wash off all the dirt in a few minutes. There are may reasons you shouldn't leave a battery sit outside, one is they are worth 10-$20 for scrap!
[Reply]  [No Email]
Mike (WA)
11-14-2012 06:02:09
174.31.205.62
I had a tractor that sat for 4 years, outside, with top post battery exposed to the weather (and disconnected). It started the tractor without external charging when I finally got tractor fixed. Average rainfall here is about 40 inches a year.
[Reply]  [No Email]
LJD
11-14-2012 06:00:47
75.194.101.226
All flooded lead-acid batteries "self discharge" regardless if wet or dry. Heavy duty batteries with more antimony inside discharge even faster. Most auto batteries discharge at 5%-10% per month when unhooked. Some AGM (absorbed glass mat) lead-acid batteries discharge less.
[Reply]  [No Email]
John B.
11-14-2012 05:58:04
38.114.64.174
Moisture between the posts of a battery will cause a light discharge. It can take months, but as the moisture collects dust and it stays moist the faster the discharge. This is why they recommend keeping a battery clean.
Many people have not heard of or seen this. Take a volt meter, put one lead on one post and touch the top of the battery anywhere and watch what reading you get. This proves that moisture on top of a battery conducts electricity.
[Reply]  [No Email]
jackinok
11-14-2012 05:45:21
162.58.82.136
probably not,wont help it,but i doubt it will discharge it.driving in the rain leaves underhood components wet,and they dont discharge.sun on the case is probably worse because they are not likely to be uv protected very well. but that would take some time.
[Reply]  [No Email]
504
11-14-2012 18:19:21
199.127.54.155
 Re: Battery Question in reply to jackinok, 11-14-2012 05:45:21
If you check on the golf car sites, they all say to keep the top of batteries dry.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
