TractorLinks.com
Tractor Talk Discussion Forum
Re: 1566....not mcv pump
DeltaRed
11-13-2012 17:17:42
Does your 3 point work?how about PTO?If they dont work then the PTO drive is stripped out of the pressure plate.That will require a 'split'.If they still work,you prrobably have an air lock,or are sucking air at the oring passage between the transmission/rear end housings.Add 5 gallon or so above the full mark.Common 'fix' on IH tractors.These are the most likely causes of your problems.
